Joker failed to open - dump sent
cybergrimes
Re: Joker failed to open - dump sent
#16 Post by cybergrimes » Sat Jan 11, 2020 10:46 pm
I'm working with a regular retail release from Walmart, no good on my end.
I'm confused, some of you sent hash files and say its now working but the hashed keys file in the sticky post is still dated Dec 9th 2019?
I'll send in my dump file obviously
#17 Post by MartyMcNuts » Sun Jan 12, 2020 12:20 am
cybergrimes wrote: Sat Jan 11, 2020 10:46 pm I'm working with a regular retail release from Walmart, no good on my end.
We don't use the hash key txt file any more. The latest keys are downloaded automatically in the sdf file, sometimes when you first open MakeMKV but usually when starting a back-up.
cybergrimes
#18 Post by cybergrimes » Sun Jan 12, 2020 1:50 am
MartyMcNuts wrote: Sun Jan 12, 2020 12:20 am
Thanks for the tip, I didn't mention but I had manually updated the sdf.bin file too! (it never auto downloads for me)
I did it again before replying but still no dice so I finally did the work to fix the auto-download issue (removed some geo-IP filtering on my Unifi router and changed the DNS on my Adguard from Cloudflare to Google) and the disc is decrypting successfully now. I noticed when I placed the SDF in the MakeMKV data directory it would disappear when the program is started, I assumed it was consuming the file as expected but did noticed this last time that the modified time of the _private_data.tar was unchanged. That modified time did change once I corrected the SDF auto update :o
Anyway, glad it's working now ; )
Athenic
#19 Post by Athenic » Sun Jan 26, 2020 5:42 pm
Is anyone still having an issue?
Just purchased Joker from Amazon NA and I'm getting failures. Sent the dump over but, maybe I am doing something wrong (never had an issue before).
Thanks for the help!
slashdolphin
#20 Post by slashdolphin » Fri Jan 31, 2020 5:01 am
Can't rip JOKER 4K UHD (JAPAN Edition).
Sent dump for my disc.
Best Rwgards.
slashdolphin
#21 Post by slashdolphin » Mon Feb 03, 2020 1:01 pm
slashdolphin wrote: Fri Jan 31, 2020 5:01 am Can't rip JOKER 4K UHD (JAPAN Edition).
Best Rwgards.
Now it works properly.
mkvpip
#22 Post by mkvpip » Mon Mar 30, 2020 6:52 pm
My retail UHD version of Joker isn't ripping.
Latest version of MakeMKV, internet up & working.
Attached dump file.
Is there a new key?
MKB20_v72_Joker_C395.tgz
Dump file
(142.32 KiB) Downloaded 609 times
#23 Post by Woodstock » Mon Mar 30, 2020 6:59 pm
The file needs to be emailed to svq@makemkv.com if you want it processed in a timely manner. Attaching files on the forum does not get it to Mike's automated process.
mkvpip
#24 Post by mkvpip » Mon Mar 30, 2020 7:11 pm
Thank you. Done.
