LG BP60NB10
Re: LG BP60NB10
#16 Post by MartyMcNuts » Sat Jan 11, 2020 1:56 am
Billycar11 wrote: Sat Jan 11, 2020 1:46 am
Bluntman wrote: Sat Jan 11, 2020 12:34 am Resurrecting a couple month old thread. I just got a BP60NB10 1.00. Am wondering how I flash it. I’ve done internals no problem. But the app just hangs at 0%.
Is there some trick with slim externals you need to do?
Thank you in advance for any insights.
1.00 should just work
Nah, I'm pretty sure you need BP60NB10_1.00-MK.
@Bluntman, just download the modified ASUS flasher + firmware packs and flash BP60NB10_1.00-MK
Bluntman
Re: LG BP60NB10
#17 Post by Bluntman » Sat Jan 11, 2020 2:03 am
If 1.00 should just work, why is there an MK 1.0 version in the firmware pack, and no it does no just work I can assure you. However I will now try it on multiple other computers. I used it with the computer I use to do drive flashes.
Re: LG BP60NB10
#18 Post by MartyMcNuts » Sat Jan 11, 2020 2:09 am
Bluntman wrote: Sat Jan 11, 2020 2:03 am
As I said before, flash BP60NB10 1.00 MK with the ASUS flasher and you will be good to go!
Bluntman
Re: LG BP60NB10
#19 Post by Bluntman » Sat Jan 11, 2020 2:33 am
MartyMcNuts wrote: Sat Jan 11, 2020 2:09 am
I just finished trying your advice Marty, I got an updating error #3 using the ASUS tool.
So, no go. Wonder why this is being a pain the you know what.
Any other insights appreciated.
Re: LG BP60NB10
#20 Post by MartyMcNuts » Sat Jan 11, 2020 2:53 am
Bluntman wrote: Sat Jan 11, 2020 2:33 am
Are you using the latest version of the flasher, from 24.08.2019? It should work. Can you try downloading it again and re-trying?
Bluntman
LG BP60NB10
#21 Post by Bluntman » Sat Jan 11, 2020 3:28 am
I was indeed using the latest version.
However I took it to another rig, and it definitely worked! Most pleased. Annoyed it was my rig for some reason though.
Anyways, thank you for your help Marty.
Kind Regards
Re: LG BP60NB10
#22 Post by MartyMcNuts » Sat Jan 11, 2020 6:27 am
Bluntman wrote: Sat Jan 11, 2020 3:28 am I was indeed using the latest version.
However I took it to another rig, and it defiantely worked! Most pleased. Annoyed it was my rig for some reason though.
Kind Regards
You're welcome!
