Joker failed to open - dump sent
rbphelan
#1 Post by rbphelan » Tue Jan 07, 2020 4:43 pm
Joker 4K retail failed to open. Sending dump now.
crzyirishman
Re: Joker failed to open - dump sent
#2 Post by crzyirishman » Tue Jan 07, 2020 7:20 pm
Just had the same issue. How does this work? Do I need to send a dump somewhere?
zltful
#3 Post by zltful » Tue Jan 07, 2020 8:52 pm
You shouldn't need to send in if it is for the same retail disc set.
If it is for a rental like Red Box or Netflix, then you can.
I don't have the email handy to mail the dump file to but someone should chime in with it soonish.
wschmitt55
#4 Post by wschmitt55 » Tue Jan 07, 2020 9:32 pm
Same issue for me.
Dumb question: how do I send a dump file?
rbphelan
#5 Post by rbphelan » Tue Jan 07, 2020 10:00 pm
As I've already sent the dump file you shouldn't need to send another. Usually in a day or so (sometimes within hours) Mike will update the key file. Keep trying and eventually it should work. If you need to send a dump file see the hashed keys note pinned at the top of this section. Sometimes there are other versions that will require additional keys. Give it time. The blu-ray worked just fine.
#6 Post by d00zah » Tue Jan 07, 2020 10:25 pm
Same issue for me.
https://www.makemkv.com/forum/viewtopic ... 12&t=16883
Refer to section 'How do I discover the key for a disc I have?'.
crzyirishman
#7 Post by crzyirishman » Tue Jan 07, 2020 10:33 pm
Appreciate it!
heyriddle
#8 Post by heyriddle » Wed Jan 08, 2020 12:57 am
I just sent the RedBox dump file in case it is different than the retail dump sent in earlier.
rbphelan
#9 Post by rbphelan » Wed Jan 08, 2020 12:55 pm
Retail version is working.
Thanks Mike!!!
sanman68
#10 Post by sanman68 » Wed Jan 08, 2020 2:54 pm
Redbox version is working. Thanks
palmerwallace
#11 Post by palmerwallace » Fri Jan 10, 2020 12:19 am
Anyone having issues with playback right after the title card? Weird that I have no issues playing the file back on a SSD drive, but when I place the MKV rip onto my NAS it stutters throughout the entire exchange with the therapist. Picture and audio both stutter...not like the audio stutter on Black Hawk Down UHD.
allavallava
#12 Post by allavallava » Fri Jan 10, 2020 6:02 am
4K retail version still a no go... Anyone have success?
rbphelan
#13 Post by rbphelan » Fri Jan 10, 2020 4:32 pm
It worked for me - purchased at BestBuy. You may have a different key so send in a dump file.
allavallava
#14 Post by allavallava » Sat Jan 11, 2020 10:35 am
Thanks for the heads up. Dump file submitted.
allavallava
#15 Post by allavallava » Sat Jan 11, 2020 3:04 pm
Sent my file earlier, and I am good to go! Thanks team!
