ragico
Post by ragico »
Donpablo80 wrote: Tue Jan 07, 2020 11:08 pm
ragico wrote: Tue Jan 07, 2020 7:56 pm I made both the single and double layer DV with dvdfab.
Both play perfectly on LG C8 via Sony UBPX700.
The single layer version plays perfectly on Panasonic GX810 via Amazon firestick 4k and plex beta.
Which version of DVDFab are you using? The newest versions doesn't have the single layer option.
Version x64 11.0.6.6
ragico
Post by ragico »
jesper1994 wrote: Wed Jan 08, 2020 10:55 am
My LG oled c7 plex app is playing dolby vision files fine, however via the amazon firestick 4k app dolby vision is not triggered. Do you know for sure that this is possible?
Yes, single layer (but not all the files play. Some only audio and black screen. Gemini man plays correctly via plex).
DaMacFunkin
Post by DaMacFunkin »
Angryunibrow wrote: Wed Jan 08, 2020 5:15 am
DaMacFunkin wrote: Tue Jan 07, 2020 9:24 pm Has anyone done a single layer of Bumblebee? Tried from 2different sources and occasionally the reds go pink then green, bumble himself sometimes goes from orange to red then pale yellow whilst sometimes skin tones can be green, this is via Plex on C7 and C9.
I’ve done a double layer and it’s fine...?
I've experienced color issues using the single layer DVDFab files in my C8 using the internal Plex app on certain movies.
Started using infuse on the ATV4K and every file plays back flawless including subtitles embedded.
I think it's just compatability with the Plex app on WebOS and the files DVDfab makes.
Again it was speratic and only on certain movies.
Right now Infuse has been Rock solid and seems to be the less problematic, at least for me.
Possible, I have also read about people having synch problems when playing the DV track via UHD BD on this title but not in the HDR10 track, so maybe it is a mastering error on one of the layers.
jesper1994
Post by jesper1994 »
ragico wrote: Wed Jan 08, 2020 11:25 am
For me they are also playing, however they are triggering HDR instead of dolby vision. Furthermore I can not find anywhere that plex on firestick 4K supports dolby vision. Can someone check with an LG oled? Do you know for sure that it is triggering dolby vision?
Donpablo80
Post by Donpablo80 »
ragico wrote: Wed Jan 08, 2020 11:23 am
Thx, this newest version they brought back the single layer option. Just made a singel layer mp4 of Gemini Man and it plays perfect on my LG C7 and XPlay and looks beautiful
Angryunibrow
Post by Angryunibrow »
DaMacFunkin wrote: Wed Jan 08, 2020 1:08 pm
I've fixed the audio synch issue when I made my files, there is an issue on the UHD Blu-ray.
The audio on the UHD Blu-ray is -210ms out-of-synch (DV, or HDR)
I've fixed this on my end when making the .wav files to create the DTS-HD MA 7.1 tracks.
ragico
Post by ragico »
jesper1994 wrote: Wed Jan 08, 2020 2:19 pm
On the firestick 4K you need the plex beta to trigger DV single layer.
kazuma
Post by kazuma »
edit solved.
Angryunibrow
kazuma wrote: Wed Jan 08, 2020 9:18 pm i 'm making a mp4 dv file with dvdlab. is this dual layer or singlelayer? gemini man stutters with the tool of grencola on my LG C9. can anybody show me the way?
You should be using the Ripper, not Converter.
There should be NO encoding happening when making the DV .MP4
DaMacFunkin
Err not sure, some of it is German but it would seem to say that you are converting the video stream to H264.
Donpablo80
Go to the ripper module, choose the Dolby Vision tv preset. Then in settings choose single layer. I think you need te newest version of DVDFab 11.0.6.6
hackins
Post by hackins »
Donpablo80 wrote: Wed Jan 08, 2020 10:07 pm Go to the ripper module, choose the Dolby Vision tv preset. Then in settings choose single layer. I think you need te newest version of DVDFab 11.0.6.6
tell me please what to do to with the audio when doing rip dolby vision single layer?
DaMacFunkin
hackins wrote: Thu Jan 09, 2020 12:09 pm
Choose to convert audio to one of the options in the Dolby Vision rip settings and live with it, or if DTS-HD choose no audio and mux that in separately (not advised for noobs).
box4m
Post by box4m »
DaMacFunkin wrote: Thu Jan 09, 2020 4:01 pm
My files wont play on MXPlayer / 2019 Shield after muxing DTS with mp4box - does it work for anyone?
DaMacFunkin
I don’t use MX player, I find it ropey, use Plex or MrMC.
