Joker failed to open - dump sent
rbphelan
Post by rbphelan »
Joker 4K retail failed to open. Sending dump now.
crzyirishman
Re: Joker failed to open - dump sent
Post by crzyirishman »
Just had the same issue. How does this work? Do I need to send a dump somewhere?
zltful
Post by zltful »
You shouldn't need to send in if it is for the same retail disc set.
If it is for a rental like Red Box or Netflix, then you can.
I don't have the email handy to mail the dump file to but someone should chime in with it soonish.
wschmitt55
Post by wschmitt55 »
Same issue for me.
Dumb question: how do I send a dump file?
rbphelan
Post by rbphelan »
As I've already sent the dump file you shouldn't need to send another. Usually in a day or so (sometimes within hours) Mike will update the key file. Keep trying and eventually it should work. If you need to send a dump file see the hashed keys note pinned at the top of this section. Sometimes there are other versions that will require additional keys. Give it time. The blu-ray worked just fine.
Post by d00zah »
wschmitt55 wrote:
Tue Jan 07, 2020 9:32 pm
Same issue for me.
https://www.makemkv.com/forum/viewtopic ... 12&t=16883
Refer to section 'How do I discover the key for a disc I have?'.
crzyirishman
rbphelan wrote:
Tue Jan 07, 2020 10:00 pm
Appreciate it!
heyriddle
Post by heyriddle »
I just sent the RedBox dump file in case it is different than the retail dump sent in earlier.
rbphelan
Post by rbphelan »
Retail version is working.
Thanks Mike!!!
sanman68
Post by sanman68 »
Redbox version is working. Thanks
palmerwallace
Post by palmerwallace »
Anyone having issues with playback right after the title card? Weird that I have no issues playing the file back on a SSD drive, but when I place the MKV rip onto my NAS it stutters throughout the entire exchange with the therapist. Picture and audio both stutter...not like the audio stutter on Black Hawk Down UHD.
allavallava
Post by allavallava »
4K retail version still a no go... Anyone have success?
rbphelan
Post by rbphelan »
allavallava wrote:
Fri Jan 10, 2020 6:02 am
It worked for me - purchased at BestBuy. You may have a different key so send in a dump file.
allavallava
rbphelan wrote:
Fri Jan 10, 2020 4:32 pm
Thanks for the heads up. Dump file submitted.
allavallava
Sent my file earlier, and I am good to go! Thanks team!
