The Matrix and The Matrix Revolutions
mostlife
I have an UHD BluRay disc of The Matrix (HDR) and The Matrix Revolutions (HDR).
Both return a few uncorrectable scsi errors, after which the ripping stops.
Here is my log:
MakeMKV v1.14.7 win(x64-release) started
Downloading latest SDF to C:\Users\Joannes/.MakeMKV ...
Using LibreDrive mode (v05 id=0FA242DD4D0B)
Title #00201.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00140.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00141.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00055.mpls was added as title #0
Title #00054.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00301.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #1
Title #00053.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00004.m2ts was added as title #2
Title #00014.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00038.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00002.m2ts was added as title #3
Title #00026.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory F:/rip/The Matrix (1999)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '28981850112'
It is currently still trying to rip, but I suspect it is going to quit with an error very soon.
How do I attach the logs?
Kind regards,
Joannes Wyckmans
Here is my log:
Kind regards,
Joannes Wyckmans
Re: The Matrix and The Matrix Revolutions
Can you provide some more info. Let's start with:mostlife wrote: Tue Jan 07, 2020 3:05 am Hi,
Here is my log:
Kind regards,
Joannes Wyckmans
1. What drive are you using?
2. How is it connected to PC?
mostlife
Drive is: BD-RE ASUS BW-16D1HT 3.10
Connected over sata...
edit: the matrix reloaded went fine
mostlife
This is my drive info:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: XXXXXXXXXXX
Bus encryption flags: 1F
Highest AACS version: 61
Firmware version: 3.10
Disc Information
Disc is being loaded
PS:
It seems one of the failed matrix discs now ripped..
trying the other one..
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Disc Information
PS:
Ok, cool. Glad you got one of them working. You may need to give the other disc a good clean before trying again.mostlife wrote: Tue Jan 07, 2020 3:49 am This is my drive info:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Disc Information
PS:
mostlife
It still did not work with the last disc, namely revolutions..
I will try again later today or maybe tomorrow.
In the meanwhile I would like to know how to attach a log file...
I can't remember. Is that a 3 layer disc? Anyway, I think I had trouble with that one the first time. I switched drives and it ripped fine.mostlife wrote: Tue Jan 07, 2020 5:45 am It still did not work with the last disc, namely revolutions..
Sometimes there are discs that a particular drive just won't read, no matter what you do. This is why most of us have 2 or more drives. If a disc doesn't read properly in drive 1, it generally will in drive 2.
I personally have 3 drives.
My main drive is a BH16NS55 with 1.02.
Drive 2 is a WH16NS60 with 1.00.
Drive 3 is a BH16NS55 cross-flashed to an ASUS BW-16D1HT 3.02.
its a dual layer BD 66 this site https://www.blu-ray.com/movies/The-Matr ... ay/208210/ is really useful for seeing what disk type it isMartyMcNuts wrote: Tue Jan 07, 2020 6:06 am
LOL... I use blu-ray.com all the time and didn't think to check the disc info. Anyway, here is the Disc Info for The Matrix Trilogy, which is what I have.Billycar11 wrote: Tue Jan 07, 2020 9:52 amits a dual layer BD 66 this site https://www.blu-ray.com/movies/The-Matr ... ay/208210/ is really useful for seeing what disk type it isMartyMcNuts wrote: Tue Jan 07, 2020 6:06 am
Discs
4K Ultra HD
Blu-ray Disc
Nine-disc set (3 BD-100, 3 BD-25, 3 BD-50)
Here is the link. https://www.blu-ray.com/movies/The-Matr ... ay/212786/
Hmm I see that's weird that a different set is on a different format bd I would think they are the same even us version of trilogy is bd 100 and standalone is bd 66 I wonder what one is """"Better""" lolMartyMcNuts wrote: Tue Jan 07, 2020 10:11 am
Just for curiosity's sake, I went and got my trilogy out of the cupboard and loaded each UHD into MakeMKV.Billycar11 wrote: Tue Jan 07, 2020 11:34 amHmm I see that's weird that a different set is on a different format bd I would think they are the same even us version of trilogy is bd 100 and standalone is bd 66 I wonder what one is """"Better""" lolMartyMcNuts wrote: Tue Jan 07, 2020 10:11 am
The Matrix
Data capacity: 64.83 Gb
Disc type: BD-ROM UHD
Number of layers: 3
The Matrix Reloaded
Data capacity: 86.33 Gb
Number of layers: 3
Data capacity: 66.23 Gb
Number of layers: 3
agneva
i´ve seen there are 3 titels on the Matrix 4K Bluray, each ~65GB.
is one HDR and one Dolbyvision ?
Couldn´t see differences in video info.
mostlife
I have the matrix with 58GB average. It has dolby vision and Thru HD / atmos 7.1 audio.
It is the one for Belgium, luxembourg and dutch market(BENELUX). Those 2-3 markets usually have a shared printing in french and dutch. None of them rip. The quit at about 24GB
Neo369
hi could you send me a Google drive with all the 4K Matrix thank you
Shouldn't be necessary, as the disk rips. You just need to select the correct track for what you want, as mentioned above.hi could you send me a Google drive with all the 4K Matrix thank you
