Grencola
#976 Post by Grencola » Tue Jan 07, 2020 12:59 am
deadchip12 wrote: Mon Jan 06, 2020 2:32 am It's possible that tvs will support both dolby vision and hdr10+ in the very near future. Is there a way to make hdr10+ work through mp4 mux like dolby vision? I checked the Alien 4k Remastered disc (an hdr10+ title) and it seems there is only 1 video stream (compared to usually 2 streams in a dolby vision disk).
my tv (vizio p-series quantum x) already does both hdr10+ and dolby vision. hdr10+ is awesome, it's handled just like regular hdr10 so nothing extra is needed, it works right in an mkv (remux and x265!) with full hd audio atmos etc. and looks just as amazing as Dolby vision. whether I use kodi, or cast it to my tv with localcast, it just works. I'd love it if all movies went to that!
Angryunibrow
#977 Post by Angryunibrow » Tue Jan 07, 2020 4:23 am
Donpablo80 wrote: Mon Jan 06, 2020 6:28 pm Anyone tried to mux Gemini Man to a Dolby vision MP4? I got massive stutter on my LG OLED with DV-Maker and DVDFab. Maybe because of the 60fps video.
So far perfectly fine on ATV4K using infuse along with DTS-HD MA 7.1.
Connected to a C8
#978 Post by MartyMcNuts » Tue Jan 07, 2020 4:44 am
Grencola wrote: Tue Jan 07, 2020 12:59 am
my tv (vizio p-series quantum x) already does both hdr10+ and dolby vision. hdr10+ is awesome, it's handled just like regular hdr10 so nothing extra is needed, it works right in an mkv with full hd audio atmos etc. and looks just as amazing as Dolby vision. I'd love if all movies went to that!
Ok, so what we really need is a way to convert DV to HDR10+!!
scradion
#979 Post by scradion » Tue Jan 07, 2020 6:40 am
The only way to get it to play straight on the LG tvs without the massive stuttering is to use DVDfab to make it into a single layer DV stream but it probably isn't real Dolby Vision but it is 60fps and still looks amazing. It could be that the 866Mbps wifi just isn't fast enough but it still lags the same when played through usb so it sounds like either the usb 2 port isn't fast enough or more likely the SoC just isn't fast enough to handle the movie. I bet the Nvidia Shield 2019 would have no issues with the Dual Layer if it would have DL support, but it doesn't and may never get it.
Donpablo80
#980 Post by Donpablo80 » Tue Jan 07, 2020 2:09 pm
scradion wrote: Tue Jan 07, 2020 6:40 am
I'll try to make a single layer file with DVDFab.
The HDR10 version of the movie is playing just fine, maybe its the combo of DV and 60fps that the B7 cant handle.
scradion
#981 Post by scradion » Tue Jan 07, 2020 6:21 pm
Donpablo80 wrote: Tue Jan 07, 2020 2:09 pm
The LG E8 with an Alpha 9 cpu can't even play it smoothly and its a year newer than the B7 and neither are a slouch by any means. It plays every other DV DL movie perfectly besides this one.
mulucy
#982 Post by mulucy » Tue Jan 07, 2020 7:10 pm
Not real Dolby Vision?
mulucy
#983 Post by mulucy » Tue Jan 07, 2020 7:13 pm
I created a single-layer with DVDFab too and it works fine with Apple TV 4K. The only problem I encountered, in the beginning, it was only playing in HDR10 only, for some reason ( although Profile 5 is not compatible with HDR10 like Profile 7 ). Make sure to choose RBG High under the video settings on your Apple TV if you have one.
ragico
#984 Post by ragico » Tue Jan 07, 2020 7:56 pm
I made both the single and double layer DV with dvdfab.
Both play perfectly on LG C8 via Sony UBPX700.
The single layer version plays perfectly on Panasonic GX810 via Amazon firestick 4k and plex beta.
DaMacFunkin
#985 Post by DaMacFunkin » Tue Jan 07, 2020 9:20 pm
daddy wrote: Mon Jan 06, 2020 6:49 pm
I have stutter too (LG 55C7) when i try to play the mp4 in DV.
No stutter at all with the same mp4 file when i play it in HDR10 on a box with CoreElec.
Single layer DV Gemini Man plays fine @ 60fps via inbuilt Plex app on 55” LG C7, if playing from external player you will need a really good HDMI cable got this, if playing internally and getting stutter then it’s your motion / interpolation settings.
DaMacFunkin
#986 Post by DaMacFunkin » Tue Jan 07, 2020 9:24 pm
Has anyone done a single layer of Bumblebee? Tried from 2different sources and occasionally the reds go pink then green, bumble himself sometimes goes from orange to red then pale yellow whilst sometimes skin tones can be green, this is via Plex on C7 and C9.
I’ve done a double layer and it’s fine...?
Donpablo80
#987 Post by Donpablo80 » Tue Jan 07, 2020 11:08 pm
ragico wrote: Tue Jan 07, 2020 7:56 pm I made both the single and double layer DV with dvdfab.
Which version of DVDFab are you using? The newest versions doesn't have the single layer option.
#988 Post by RESET_9999 » Tue Jan 07, 2020 11:11 pm
Same here with oled c8.
on my Sony x700, DV mp4 + lpcm 7.1: the first 2 minutes play fine and then it starts stuttering.
It plays fine with AC3 5.1 ... So I guess 60fps DV + lossless audio is too much for my player.
I did not test the Shield because I think too that DVDfab's single layer files are not proper DV.
I might try to burn a BD just for testing.
Angryunibrow
#989 Post by Angryunibrow » Wed Jan 08, 2020 5:15 am
DaMacFunkin wrote: Tue Jan 07, 2020 9:24 pm Has anyone done a single layer of Bumblebee? Tried from 2different sources and occasionally the reds go pink then green, bumble himself sometimes goes from orange to red then pale yellow whilst sometimes skin tones can be green, this is via Plex on C7 and C9.
I've experienced color issues using the single layer DVDFab files in my C8 using the internal Plex app on certain movies.
Started using infuse on the ATV4K and every file plays back flawless including subtitles embedded.
I think it's just compatability with the Plex app on WebOS and the files DVDfab makes.
Again it was speratic and only on certain movies.
Right now Infuse has been Rock solid and seems to be the less problematic, at least for me.
jesper1994
#990 Post by jesper1994 » Wed Jan 08, 2020 10:55 am
My LG oled c7 plex app is playing dolby vision files fine, however via the amazon firestick 4k app dolby vision is not triggered. Do you know for sure that this is possible?
