every 20 min audio drops out
katana104
Post by katana104 »
every blue ray I copy the audio drops every 20 min for a second and then will keep dropping out till I pause. Then it will work for 20 min and then it starts all over again. So every 20 min after i loose audio I have to pause, Help
Re: every 20 min audio drops out
Do all of your Blurays have Cinavia copy protection on them? Are you playing them through a Bluray-certified device?
katana104
Post by katana104 »
I believe its removed by the software
MakeMKV does not remove Cinavia. I know of only one software package that does, and it only removes it from disks they've already processed.
The secret is to NOT play back through a BD-certified device. If it isn't BD-certified, it will ignore Cinavia.
katana104
Post by katana104 »
ok so if i use makeMkv and play with kodi on a nvidia shield I should have no problems?
katana104
Post by katana104 »
Sorry I am using Kodi on an nvidia shield and having this issue by the way.
The shield should ignore Cinavia. But, apparently some TVs have it.
A test - on one of the files that has the problem, pause at 10 minutes. Restart.
Does it drop out at the 20 minute mark, or 20 minutes later?
If it's Cinavia, it will occur at 20 minutes after you restart. If it's a problem with the file, it will happen at the 20 minute mark.
katana104
Post by katana104 »
ok ill give it a shot. But not all movies have it correct? It happens on every blu ray rip.
Correct - Cinavia is actually rare "in the wild", but it does fit the behavior you describe.
Other things that can be problems are bandwidth issues on playback, but that would normally vary with system load; Problems with the playback buffering in the player software; Incompatible audio codecs. Just how are you playing the files?
