Mission Impossible 3 UHD rip failed
maddog510
#1 Post by maddog510 » Sun Jul 22, 2018 3:32 am
I got about 30 minutes into ripping MI3 when my drive started making noises & the ripping slowed down. I had left & came back about 20 minutes later & discovered the rip had ceased but I think my drive might be damaged as well. It's no longer reading any blu rays. 4K or 1080p. I have a LG WH16NS40. This is the 2nd drive I had go belly up on me trying to rip a 4K disc.
jonghotti
Re: Mission Impossible 3 UHD rip failed
#2 Post by jonghotti » Wed Jul 25, 2018 7:59 am
maddog510 wrote:I got about 30 minutes into ripping MI3 when my drive started making noises & the ripping slowed down. I had left & came back about 20 minutes later & discovered the rip had ceased but I think my drive might be damaged as well. It's no longer reading any blu rays. 4K or 1080p. I have a LG WH16NS40. This is the 2nd drive I had go belly up on me trying to rip a 4K disc.
Contents of the log window would help in cases like this.
bjhess
#3 Post by bjhess » Sun Dec 08, 2019 6:42 pm
Reviving this thread because I'm having the same problem. Information:
MakeMKV 1.14.7 Registered
OS device name: /dev/rdisk2
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KL4J6FB3550
Bus encryption flags: 1F
Highest AACS version: 68
Firmware version: 3.10
Here's a log when ripping the entirety of 00800.mpls:
MakeMKV v1.14.7 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/barry/MakeMKV_log.txt
Optical drive "BD-RE ASUS BW-16D1HT 3.10d" opened in OS access mode.
Using LibreDrive mode (v05 id=0FA242DD4D0B)
Title #00109.mpls has length of 21 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00104.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00063.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00096.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00084.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00093.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00080.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00073.mpls has length of 21 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00069.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
File 00800.mpls was added as title #0
Title #00070.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00108.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00068.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00107.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00106.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00020.mpls has length of 50 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00105.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00066.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00064.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00103.mpls has length of 21 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00095.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00086.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00079.mpls has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00035.mpls has length of 110 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00033.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00060.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00059.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00055.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00027.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00023.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00045.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00041.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00040.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00037.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00035.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00034.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00030.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00054.m2ts has length of 11 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00029.m2ts has length of 11 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00032.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00031.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00057.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00056.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00028.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00026.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00018.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00025.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00024.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00000.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00002.m2ts has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00003.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00042.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00129.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00001.m2ts has length of 50 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00010.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00058.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
File 00005.m2ts was added as title #1
Title #00039.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00038.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00004.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00147.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00146.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00145.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00144.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00022.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00143.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00017.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00142.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00021.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00141.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00020.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00140.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00019.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00139.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00008.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00138.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00016.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00137.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00015.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00136.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00014.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00135.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00013.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00134.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00012.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00133.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00132.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00131.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00130.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00006.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00128.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00127.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00126.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00125.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00124.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00123.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00122.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00120.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00119.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00118.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00117.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00116.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00115.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00114.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00113.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00112.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00111.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00110.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00109.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00108.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00107.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00106.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00105.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00104.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00103.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00102.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00044.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00011.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00009.m2ts has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00007.m2ts has length of 16 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00036.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Saving 1 titles into directory /Users/barry/Desktop/mkv/Mission- Impossible III
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '1104936960'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '1104936960'
DEBUG: Code 1073741829 at ^#eX_+A%Tn8&;8al>[:29394758
DEBUG: Code 101000192 at ^#eX_+A%Tn8&;8al>[:29394758
DEBUG: Code 0 at B+mIsYmnIAn;);L:\dP::29395011
DEBUG: Code 0 at MK'1K\X2-eE@dY'w{!S<:29394068
DEBUG: Code 0 at B+mIsYmnIAn;);L:\dP::29394459
DEBUG: Code 539520 at B+mIsYmnIAn;);L:\dP::29393286
DEBUG: Code 0 at 4gR9l=vu8d2skdQEfM3}-:213136608
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 0 to file /Users/barry/Desktop/mkv/Mission- Impossible III/Mission- Impossible III_t00.mkv
0 titles saved, 1 failed
Thanks for any thoughts!
bjhess
#4 Post by bjhess » Fri Jan 03, 2020 8:11 pm
I watched the UHD disc today and it seemed almost locked up about 10 minutes into the movie. Eventually it recovered and had only one other little glitch somewhere during the credits. Anyway, I suspect that is related to MakeMKV not being able to rip this disc.
#5 Post by Coopervid » Fri Jan 03, 2020 8:25 pm
Looks like a dirty disc even if it's new. Clean it with soap and warm water. Clean then again with a microfiber cloth used usually to clean glasses. Try again.
bjhess
#6 Post by bjhess » Sat Jan 04, 2020 4:13 am
It was worth a shot, but unfortunately I get the same errors after cleaning. I suspect it is a manufacturing defect.
