Verdammnis - The Girl Who Played with Fire (2009)
mgutt
Post by mgutt » Thu Nov 28, 2019 3:00 pm
This german Blu-Ray contains the complete movie in two different segments:
Titelinformationen
Name der Quelldatei: 00000.mpls
Länge: 1:28:04
Anzahl der Kapitel: 16
Segmentanzahl: 1
Segmentkarte: 0
Name der Ausgabedatei: title_00.mkv
Titelinformationen
Name der Quelldatei: 00015.mpls
Länge: 1:28:11
Segmentanzahl: 1
Segmentkarte: 16
Name der Ausgabedatei: title_01.mkv
I will create a backup through MakeMKV, replace one of the m2ts segment files and try to play the movie. We will see which one is needed ;)
EDIT: Both parts are important. All discs (Verdammnis, Verblendung, Vergebung) contain each movie split in two parts.
scarfaceno1
Re: Verdammnis - The Girl Who Played with Fire (2009)
Post by scarfaceno1 » Fri Jan 03, 2020 7:24 am
Got a Question to this.
I backuped only title 1. So I had the Movie, but not in Directors Cut. When I backup both Segments, how to Combine them in a way, that the Directors Cut can be watched?
Thank you.
scar
mgutt
Post by mgutt » Fri Jan 03, 2020 3:26 pm
To save space? This depends on the player you want to use. For example Plex or Emby do not support playlists or direct BD playback. They would need both movies in total length in two different mkv files.
If you use Kodi you could create a backup of the BD and then you could try to build a new BD (ISO) on yourself starting different playlists. In this step all irrelevant mpls files and menus could be removed as well.
