Angel Was Fallen 4K UHD won`t rip- Volume Key Unknown
Angel Was Fallen 4K UHD won`t rip- Volume Key Unknown?
HayItzDatGuy
Re: Angel Was Fallen 4K UHD won`t rip- Volume Key Unknown
Angel Was Fallen.......Angel Has Fallen?
In the MakeMKV log (the white bit with text in it at the bottom) you should see a reference to a file, something like:
Mac: Saved AACS dump file as /Users/Rodney M/Library/MakeMKV/MKB20_v??_Angel_Has_Fallen_???.tgz
Windows: Saved AACS dump file as /Users/Rodney M/.MakeMKV/MKB20_v??_Angel_Has_Fallen_???.tgz
This file needs to be emailed to svq@makemkv.com. Then try the disc again in a few days.
thank you, have sent the file
Hallo .... had handed over the .tzg with email to the same German disc .Unfortunately, opening is not yet possible. Seems to be a difficult case
wish everyone a happy new year 2020
klappt... Danke !
klappt... Danke !
Unibrowser
I ripped mine just fine. Both the bluray and UHD Bluray are in my plex library as we speak.
This is the way
