fosterjazz
I am new to this support forum but I have been a licensed Makemkv user for some time and reading the recommendations from this forum prior to making my purchase.
I purchased and just received my new LG WH16NS40(NS50) 1.02.
Per MakeMKV v1.1.14.7 my drive specs are listed below.
Product: BD-RE WH16NS60
Revision 1.02
Highest AACS version: 61
LibreDrive Inforation
Hardware support: Yes
Firmware support: no
Firmware type: Original (pathed version available)
Firmware version: 1.02
DVD all Regions:Possible (with patched firmware)
BD raw metadata: Possible (with patched firmware)
I downloaded both the mk-firmware-pack-20191013.zip and mk-firmware-pack-20191206.zip files.
Copied the ASUS_ODD_FW_Changer (Modified).exe into the same sub-folder of both but all attempts thus far have resulted in the Updating Failure #x
I also tried downgrading it from the firmware update on the LG site which appeared to have the capability of downgrading it to 1.01 but once saw the newer version it stopped with a Current FW is equal or higher!!! message.
The forum listed this model drive one the better ones so do I need to try to return it or has there been a firmware that will convert this to a Libra enabled drive?
Thank you
Curt Foster
Revision 1.02
Thank you
Curt Foster
It appears you have a WH16NS60, not a WH16NS40!!!fosterjazz wrote: Sat Dec 21, 2019 6:43 pm Hello,
Revision 1.02
Thank you
Curt Foster
For your WH16NS60 1.02, please flash WH16NS60 1.02-MK from the latest MK folder (20191206) first. After that, you can flash whatever firmware you like.
bluemonkey
Hello!
Question, i have a WH16NS40, read the procedure, i'm ok with the concept. Need to side grade then move to the final firmware. I just have a problem with the flasher itself, it tries to write a file to "userdirectory"\appdata\local\temp\ASUS_ODD_FW_Changer.exe and it's denied (and the process does not even start). I've disabled my AV just in case (initial launch flagged it as a potential malware, most likely based on assembly language usage). I'm running windows 10.
Anything silly that i missed? or not so silly?
EDIT: figured it out, i had to remove my AV to be able to run the patcher, even deactivating bitdefender would not let me run it. The double crossflash worked perfectly. Big thank you for the work done on this.
Much appreciated
bm
Much appreciated
bm
st4evr
As Marty advised it doesn’t just appear, but looks like you sure do have a WH16NS60 drive instead of a WH16NS40 drive per what MakeMKV is reporting. Carefully check your shipment box and/or the drive sticker itself to validate this, pay attention, and make sure which drive you currently have purchased before attempting to make changes.fosterjazz wrote: Sat Dec 21, 2019 6:43 pm
Revision 1.02
BumBum_2906
Hi
So i will get the ASUS BW-16D1HT tomorrow wich probably will have 3.10!
Just so i'am clear...what do i have to do to make it UHD Friendly?
Thx
Thx
st4evr
Read. There are pinned posts/guides across the forum that provide answers to these common questions. Take the time to read through them. Start here:BumBum_2906 wrote: Thu Dec 26, 2019 12:21 pm
Thx![]()
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
BumBum_2906
So i downloaded the (Modified) ASUS ODD FW Changer (24.08.2019) + UHD Friendly Firmwares + Latest MK Pack
When i get my Asus bw-16d1ht with 3.10 tomorrow i have to open ASUS ODD FW Changer and select the 3.10MK File correct?
joeyfun
Hello, I just got the following drive and I'm trying to downgrade my firmware to 1.00 It's what I've been reading I should do, if that's wrong, please let me know. I can't find the firmware to the exact model I have (MD-8107S-U3YC-UHD). I read somewhere on here that I should flash it using the BU40N_1.00 firmware. However, I'm only finding the following files in the new firmware pack provided in this thread. I don't know which one to pick. Only the top file listed has the 1.00 in its name.
Folder Location
\Downloads\(Modified) ASUS ODD FW Changer (24.08.2019) + UHD Friendly Firmwares + Latest MK Pack
DE_LG_BU40N_1.00.bin
Folder Location
\Downloads\(Modified) ASUS ODD FW Changer (24.08.2019) + UHD Friendly Firmwares + Latest MK Pack\mk-firmware-pack-20191206\MK\HL-DT-ST
BU40N-FR
BU40N-N
BU40N-FR
BU40N-R-Taiwan
BU40N-U
Device
Folder Location
Folder Location
BU40N-FR
BU40N-N
BU40N-FR
BU40N-R-Taiwan
BU40N-U
Device
Product: BD-RE BU40N
Revision: 1.01
Firmware date: 2117-12-22 12:21
Bus encryption flags: 1F
Highest AACS version: 68
Harware support: Yes
Firmware support: No
Firmware version: 1.01
Yep, that is the correct firmware.joeyfun wrote: Fri Dec 27, 2019 3:50 am Hello, I just got the following drive and I'm trying to downgrade my firmware to 1.00 It's what I've been reading I should do, if that's wrong, please let me know. I can't find the firmware to the exact model I have (MD-8107S-U3YC-UHD). I read somewhere on here that I should flash it using the BU40N_1.00 firmware. However, I'm only finding the following files in the new firmware pack provided in this thread. I don't know which one to pick. Only the top file listed has the 1.00 in its name.
Folder Location
Folder Location
BU40N-FR
BU40N-N
BU40N-FR
BU40N-R-Taiwan
BU40N-U
Device
==================================Code: Select all
Drive Information OS device name: D: Manufacturer: HL-DT-ST Product: BD-RE BU40N Revision: 1.01 Firmware date: 2117-12-22 12:21 Bus encryption flags: 1F Highest AACS version: 68 LibreDrive Information Status: Possible (with patched firmware) Drive platform: MT1959 Harware support: Yes Firmware support: No Firmware type: Original (patched version available) Firmware version: 1.01 DVD all regions: Possible (with patched firmware) BD raw data read: Possible (with patched firmware) BD raw metadata read: Possible (with patched firmware) Unrestricted read speed: Possible (with patched firmware)
Rabik
Hi guys,
I use ASUS BW-16D1HT with original fw 3.02 (UHD friendly) drive and DeUHD for making of my UHD backups. I hear during ripping of each disc some weird scrapes (like during loading of disc) in various periods (after a few seconds, 1 minute etc) but the ripping speed does not slow. The backups work OK on my Oppo, no picture distortions, dropouts etc. but I am concerned about it. I clean each disc is before inserting to drive so it is free of dust etc.
All my discs are in pristine condition and my drive is brand new. I also tried to crossflash to older fw 3.01 or 3.10MK and the same result.
It is weird because when I tried to use AnyDVD those weird scrapes are suddenly gone and the drive has normal sound when the speed is increased etc. Any idea please?
Standard Blu-ray discs work perfectly. No weird sounds.
Is such behaviour usual for ASUS BW-16D1HT drives? Hear the attached files.
I have other problems. I get some reading error in ~98% almost before an end of ripping. It is usual about this disc? That error happened only with this disc.
Another problem is with UHD Spider-Man 3. I am almost not able to load the disc. The drive makes very bad noises like corruped and these same sounds are presented during ripping too. But it is only with this disc. Others discs are "fine" and behaves as I described above.
Thank you very much.
Jim777
Hello everyone, I would love some help with my BP50NB40
Here is the info from MakeMKV:
Product: BD-RE BP50NB40
Revision: 1.02
Serial number: SIKYVJ9KB0631
Firmware date: 2119-05-03 15:10
Highest AACS version: 66
I have tried to flash both DE_LG_BP60NB10_1.00_MK_HBD and DE_LG_BP50NB40-NB50_1.01_MK_HBD firmware via the modified ASUS Changer, but have run into Update Error #3 as well as #4.
Revision: 1.02
Yep, unfortunately, those with firmware 1.02 cannot currently be cross-flashed.Jim777 wrote: Sun Dec 29, 2019 1:43 am Hello everyone, I would love some help with my BP50NB40
Revision: 1.02
Have you tried flashing the HL-DT-ST-BD-RE_BP50NB40-NB50-1.02-NM00700-211811011016 firmware from the latest MK pack?
Please try and let us know.
Jim777
That worked perfectly, and I was then able to cross-flash to DE_LG_BP60NB10_1.00_MK_HBD and the drive now seems to be behaving UHD Friendly with LibreDrive supported!MartyMcNuts wrote: Sun Dec 29, 2019 6:10 am
Excellent! I'm glad it worked for you. Thanks for the feedback!Jim777 wrote: Sun Dec 29, 2019 2:03 pmThat worked perfectly, and I was then able to cross-flash to DE_LG_BP60NB10_1.00_MK_HBD and the drive now seems to be behaving UHD Friendly with LibreDrive supported!MartyMcNuts wrote: Sun Dec 29, 2019 6:10 am
tribble
What's the worst that can happen, I brick my drive? Or is it just going to fail and give me an error number? Just want to be sure.MartyMcNuts wrote: Tue Nov 26, 2019 11:51 pmPlease read the first post of this very thread. The BP50NB40 SVC: NB50 is supported. The SVC: NB40 is not guaranteed to be flashable but you can try it if you want to.tribble wrote: Tue Nov 26, 2019 8:22 pm I did a search before asking and only found a thread from July which said LG USB drives weren't supported at all yet.
MakeMKV 1.14.4 on an air-gapped Windows 10 device.
Product: BD-RE HL-DT-ST BP50NB40
Firmware: 21141216 10:16
SVC Code: NB40
Rom Ver.: 1.00 (1.00d)
Manufactured: 2015-02-12
This device appears to be listed in the latest sdf.bin, the product, firmware and ROM all match.
I get no LibreDrive information in MakeMKV but I think that's because I have an air-gapped machine.
1) Is this specific device supported by the modified Asus Flasher?
2) Where can I find the Drive Platform information on an air-gapped machine?
3) Are NB40 devices supported at all? The Ultimate UHD Drives Guide mentions only NS50 drives and later.
