Audio Differences
oXdanXo
Audio Differences
#1 Post by oXdanXo » Sat Dec 28, 2019 8:34 pm
Hi guys,
With 4k discs playing through an xbox that is connected directly to a soundbar there is a higher quality audio.
When I rip the film to a drive and play it through the TV (TV connected to soundbar), the audio seems worse and there seems to be fewer tracks.
Is there anyway I can verify what audio track is playing?
Grauhaar
Re: Audio Differences
#2 Post by Grauhaar » Sun Dec 29, 2019 4:32 am
That's normal, because most "Smart" TVs have only limited audio supported (number of channels, no DTS and so on) and passes this bad audio stream over the internal electronic to the soundbar.
The only real working solution is to use an AV Receiver, connect all equpment (input and output), all the speakers or soundbar/desk (any soundbar is always a compromise, due to limited speakers, dynamic and virtual surround pimping) and TV on it and use this as the primary input switch for any equipment. In this case, the TV acts only as an monitor and the AV Receiver get's full control over all equipment and the audio and video signals and can interpret it (decoding and use it's amplifier -> speakers) or pass it to the output equipment (soundbar) in the best supported quality.
Good Luck :)
BlueMac77
#3 Post by BlueMac77 » Sun Dec 29, 2019 7:28 am
oXdanXo wrote: Sat Dec 28, 2019 8:34 pm Hi guys,
Playing the movie thru the TV usually does not produce high quality audio and audio is just “flat”, Grauhaar is correct. What I do is have my computer connected to a Marantz AV Receiver and large floor standing speakers and subwoofers connected to the Marantz receiver. Both the receiver and speakers must be good brands to give that thunderous explosions and crisps details.
