Sound Is Backwards
THXSND
Sound Is Backwards
Post by THXSND » Sat Dec 28, 2019 10:12 am
I've been using the latest version of the software & I notice that the sound on my 5.1 system is backwards. The main sound comes out of my rear speakers.
Anyone else have this problem???
Grauhaar
Re: Sound Is Backwards
Post by Grauhaar » Sat Dec 28, 2019 6:47 pm
What kind of audio track ? Any adio conversions done with MakeMKV?
Produce with "MediInfo" a list of the MKV file contens.
Good Luck :)
THXSND
Post by THXSND » Mon Dec 30, 2019 11:50 pm
I'm just ripping my normal Blu Rays. I'm sure it has all the audio tracks. 5.1, 7.1, 9.1, Dolby Atmos. Not sure about the audio conversion by MakeMKV, I just set it to rip & let it go. Never knew about any other options.
Is there other options??
Thanks for responding!!!
Post by Woodstock » Tue Dec 31, 2019 1:58 am
If you haven't changed your profile yet (if you don't know what that means, you haven't), there should be no conversion of the audio, other than, if you have a DTS-HD MA track, MakeMKV will optionally create a second track that only contains the "lossy" part of the DTS-HD, for compatibility. It also does this with True-HD, copying the "lossy" portion to a standard AC3 track.
There should be no changes to the mapping of the channels, though.
