Angel Was Fallen 4K UHD won`t rip- Volume Key Unknown
Rodney M
Post by Rodney M »
Angel Was Fallen 4K UHD won`t rip- Volume Key Unknown?
HayItzDatGuy
Re: Angel Was Fallen 4K UHD won`t rip- Volume Key Unknown
Post by HayItzDatGuy »
Angel Was Fallen.......Angel Has Fallen?
In the MakeMKV log (the white bit with text in it at the bottom) you should see a reference to a file, something like:
Mac: Saved AACS dump file as /Users/Rodney M/Library/MakeMKV/MKB20_v??_Angel_Has_Fallen_???.tgz
Windows: Saved AACS dump file as /Users/Rodney M/.MakeMKV/MKB20_v??_Angel_Has_Fallen_???.tgz
This file needs to be emailed to svq@makemkv.com. Then try the disc again in a few days.
Rodney M
Post by Rodney M »
thank you, have sent the file
willi3
Post by willi3 »
Hallo .... had handed over the .tzg with email to the same German disc .Unfortunately, opening is not yet possible. Seems to be a difficult case
wish everyone a happy new year 2020
klappt... Danke !
Unibrowser
Post by Unibrowser »
Rodney M wrote:
Sat Dec 28, 2019 11:18 am
I ripped mine just fine. Both the bluray and UHD Bluray are in my plex library as we speak.
This is the way
