Sound Is Backwards
THXSND
Sound Is Backwards
Post by THXSND »
I've been using the latest version of the software & I notice that the sound on my 5.1 system is backwards. The main sound comes out of my rear speakers.
Anyone else have this problem???
Grauhaar
Re: Sound Is Backwards
Post by Grauhaar »
What kind of audio track ? Any adio conversions done with MakeMKV?
Produce with "MediInfo" a list of the MKV file contens.
Good Luck :)
THXSND
Post by THXSND »
I'm just ripping my normal Blu Rays. I'm sure it has all the audio tracks. 5.1, 7.1, 9.1, Dolby Atmos. Not sure about the audio conversion by MakeMKV, I just set it to rip & let it go. Never knew about any other options.
Is there other options??
Thanks for responding!!!
If you haven't changed your profile yet (if you don't know what that means, you haven't), there should be no conversion of the audio, other than, if you have a DTS-HD MA track, MakeMKV will optionally create a second track that only contains the "lossy" part of the DTS-HD, for compatibility. It also does this with True-HD, copying the "lossy" portion to a standard AC3 track.
There should be no changes to the mapping of the channels, though.
