Alien 40th Anniversary problems -- disc or drive? (Update: apparently disc. Worked after cleaning with Novus.)
shallowturbot
Post by shallowturbot »
Consistent errors while trying to rip Alien 40th Anniversary. Have successfully ripped several other UHD discs with the same drive. Browsing other threads it's not clear to me whether this is more likely to be a problem with the disc itself or the drive/disc combination. To my untrained eye the errors in the log look more like drive/software issues being reported than just bits not arriving from the disc. All the same, I've gone through cleaning the disc and upping the number of retries, also trying the drive on different systems, all with the same result.
Different angle on the same question: has anyone successfully ripped the Alien 40th Anniversary UHD with a WH16NS40 on firmware 1.02 in an external enclosure?
Snapshot of MakeMKV window and logfile below.
MakeMKV v1.14.7 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\corp/MakeMKV_log.txt
Using LibreDrive mode (v05 id=62194E19F4EC)
Using Java runtime from C:\Program Files (x86)\Java\jre1.8.0_231\bin\java.exe
Title #00299.mpls has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
<... many skipped/added messages omitted here ...>
Title #00739.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 2 titles into directory F:/Video/ALIEN
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00728.m2ts' at offset '1626961920'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '1626961920'
DEBUG: Code 3221225488 at ]8PztK'0td`)P05'q8:29394758
DEBUG: Code 101000192 at ]8PztK'0td`)P05'q8:29394758
DEBUG: Code 0 at 0#09wVinY17cV#\_v,qo:29395011
DEBUG: Code 0 at N.*jR!M0zLg3p,94*?XT:29394068
DEBUG: Code 0 at 0#09wVinY17cV#\_v,qo:29394459
DEBUG: Code 794415 at 0#09wVinY17cV#\_v,qo:29393286
DEBUG: Code 0 at a\;2X|KY0-z5BQ^r{QzKS:213136608
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 32 to file F:/Video/ALIEN/ALIEN-FPL_MainFeature_t32.mkv
DEBUG: Code 0 at r.i/6:;$931$jo0Oh:213135389
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00732.m2ts' at offset '0'
DEBUG: Code 0 at N.*jR!M0zLg3p,94*?XT:29397610
DEBUG: Code 0 at 0#09wVinY17cV#\_v,qo:213130145
DEBUG: Code 0 at 0#09wVinY17cV#\_v,qo:121262233
DEBUG: Code 0 at 0#09wVinY17cV#\_v,qo:29393286
DEBUG: Code 0 at Hx7Qmq@*:RO3=0Bl^(?f:29399680
DEBUG: Code 0 at *~hnCI|G[w/I^^d}:213130697
DEBUG: Code 0 at a\;2X|KY0-z5BQ^r{QzKS:213136332
DEBUG: Code 0 at *~hnCI|G[w/I^^d}:121262141
DEBUG: Code 0 at PT-QVWpr6F12!+sOW+:213137528
DEBUG: Code 0 at PT-QVWpr6F12!+sOW+:213138287
Failed to save title 33 to file F:/Video/ALIEN/ALIEN-FPL_MainFeature_UR_t33.mkv
0 titles saved, 2 failed
Last edited by shallowturbot on Sat Dec 28, 2019 10:04 pm, edited 1 time in total.
Procat
Re: Alien 40th Anniversary problems -- disc or drive?
Post by Procat »
I have successfully ripped just the movie using the same drive. Sometimes you need to clean the disc multiple times, as some discs are very finicky.
shallowturbot
Thanks, and that seems to have been it. I cleaned with Novus #2 and #1 in succession, using first a microfiber then a lens cloth. I couldn't really tell any difference visually, but: disc ripped successfully.
