Judy Playlist
Steveredrum
Judy Playlist
Post by Steveredrum »
Judy [U.S.A Retail PLAYLIST = 00661.MPLS] :lol:
CaptainProton
Re: Judy Playlist
Post by CaptainProton »
Thank You
abernhart
Re: Judy Playlist
Post by abernhart »
Do you know if this is the same for Redbox?
flintstone198
Re: Judy Playlist
Post by flintstone198 »
redbox
00661.mpls
507,509,516,508,503,517,500,501,504,513,511,510,512,505,506,518,515,514,502
WynsWrld98
Re: Judy Playlist
Post by WynsWrld98 »
Netflix same?
conchshell
Re: Judy Playlist
Post by conchshell »
Confirmed this is the correct playlist for Netflix Blu-ray. Thank you!!
RaymondGTF
Re: Judy Playlist
Post by RaymondGTF »
Guys/ Girls, first of all thanks for all the hard work everyone is doing in here. It has been a plethora of knowledge in helping me with my media library. I too have had trouble with MAKE MKV in ripping the Redbox bluray of the movie "Judy." I searched multiple places and as usual I was drawn back here to this site. I have Rambo Last Blood and Judy that I cannot rip. The error message tells me my 5 tb HDD is not big enough for the output file.
Can someone add a link to the information in here that will tell me what process I need to do?
Thanks in advance
Grauhaar
Re: Judy Playlist
Post by Grauhaar »
Please provide a Debug log (see my signature how to enable it).
Also check if there is enough freespace on the HDD. And tell us how the HDD is formated (NTFS, FATxxx ....)
Good Luck :)
RaymondGTF
Re: Judy Playlist
The HDD is a 5tb seagate formated in NTFS. It is empty and only used as a scratch disk for ripping movies before they get copied over to my server.
I just retried the RIP and the error message I get is...
"The total size of all output files may reach as much as 7765727 megabytes while there are only 4672040 megabytes free on the destination drive.
Do you still want to continue?"
I have to go to work soon and it will take me a while to learn how to open end edit the DEBUG file. After a 13 + hour shift I am pretty beat, and it may be a few days before I can tackle that. Thanks
Re: Judy Playlist
How many playlists are showing up for Judy? MakeMKV is calculating 7.7TB total for the ones selected.
RaymondGTF
Re: Judy Playlist
405 total play lists. Says it will be done in 81 hours. But the HDD will be full long before that.
Grauhaar
Re: Judy Playlist
Post by Grauhaar »
You need only ONE (!) title, the correct one. So it's important to identify the title over the correct playlist. See above in this thread, there is one Playlist listed. Maybe it matches also your Blu-ray version.
Good Luck :)
RaymondGTF
Re: Judy Playlist
Thanks to all that made suggestions. I finally figured it out!
rothgar
Re: Judy Playlist
Post by rothgar »
I just received the Judy Blu-ray and it doesn't even have a 00601.mpls. The playlist jumps from 600 to 602. Any suggestions?
Re: Judy Playlist
Do you have Java installed?
If so, did you check the TOP of the list, to see if it was there?
If MakeMKV thinks it found the correct title, it moves it to the top of the list.
