Judy DVD
dkhyne
Judy DVD
Post by dkhyne »
Just got Judy for Christmas and would like to put it on my Plex Server. Has anyone had success use MakeMKV on this disc?
Re: Judy DVD
Main issue with this is that it's a Lionsgate disk, so you have to figure out which title is correct. So far, there's only been people posting about the Bluray.
Balrog469
Re: Judy DVD
Post by Balrog469 »
So far as I can tell they are all exactly the same with slight variations in the bit rates depending on segment so for example:
Length/Video data bitrate/Audio bitrate
title_t00: 01:58:18/5871kbps/440kbps
title_t04: 01:58:18/5884kbps/441kbps
title_t05: 01:58:18/5988kbps/448kbps
title_t07: 01:58:18/5886kbps/441kbps
title_t08: 01:58:18/5864kbps/440kbps
I just went with the largest one (title_t05) and it seemed to work fine.
