Easy Blu-ray movie playback!
sduensin
Post by sduensin »
After playing with MakeMKV and VLC for awhile, I put together a little script that glues the two together allowing very easy playback of Blu-ray movies. It's free, I did it for myself, and I thought I'd share it. http://www.jaegertech.net/software/cros ... y-playback
Tell your friends! :-)
Scott
akira28
Re: Easy Blu-ray movie playback!
Post by akira28 »
I registered to this forum only to thank you :D
sduensin
Post by sduensin »
akira28 wrote:I registered to this forum only to thank you :D
Thank you! You have no idea how much I appreciate that. :D
Scott
moviemaniac
Post by moviemaniac »
Very nice, it's a start!
I don't have the time right now but it would be great to tweak the script to play the longest stream - the first track isn't always the main movie...
sduensin
Post by sduensin »
moviemaniac wrote:Very nice, it's a start!
Thanks, and good point! I'll put that on the list of things to add/change for the next release.
Scott
mzilikazi
Post by mzilikazi »
Or simply start the streaming server from the MakeMKV gui and point your web browser to http://localhost:51000/web/titles and browse to the available titles. You can then open your preference in mplayer, totem, vlc, and so on.
For Debian (and presumably other distros) simply install mozilla-mplayer or totem-mozilla and the stream will start in your media player. This works with both Firefox/Iceweasel and Chrome/Chromium.
thecapsaicinkid
Post by thecapsaicinkid »
Setting the minimum length option on makemkv to something like 1hr 20mins (--minlength=4800) seems reliable for making title 0 the main feature.
Also if you wanted to use mplayer (seeking doesn't work though) instead of VLC the command would be
mplayer -fs -demuxer lavf -alang en -slang en -forcedsubsonly -cache 8192 http://localhost:51000/stream/title0.ts
For vdpau users you may use something like this
mplayer -fs -demuxer lavf -vo vdpau:hqscaling=1 -vc ffmpeg12vdpau,ffh264vdpau,ffvc1vdpau,ffwmv3vdpau, -vfm ffmpeg, -ao pulse -ac fftruehd,ffdca,ffeac3,ffac3,fflpcm, -afm ffmpeg, -alang en -slang en -forcedsubsonly -channels 6 -cache 8192 http://localhost:51000/stream/title0.ts
