My tool just uses dolbymp4muxer which just takes a dual layer m2ts / mkv and makes it mp4. it doesn't combine the layers like dvdfab does, that's proprietary tech which hasn't been reversed engineered yet. but I did notice dvdfab.exe works from a command line.. so potentially, provided you have an activated dvdfab license on your pc and I packed in all the required programs, I could make a fully automated one-click tool again where you just pick one of your uhd bd backups, and it makes you a single layer dv mp4 with the full original hd-audio retained.
				DaMacFunkin
If you mean a file that is HDR10 and DV you can’t, the Shield only supports Single layer DV files, the resulting file will not then playback in a player that only supports HDR10.
When you add a UHD full rip to DVDfab you then need to click the little spanner icon to change the setting to single layer, it defaults to double layer, that is why you are only getting HDR.
Regards.
Omg if you can create a one click tool with Dvd fab + core & HD audio, i will worship you!Grencola wrote: ↑Sun Dec 22, 2019 5:11 amMy tool just uses dolbymp4muxer which just takes a dual layer m2ts / mkv and makes it mp4. it doesn't combine the layers like dvdfab does, that's proprietary tech which hasn't been reversed engineered yet. but I did notice dvdfab.exe works from a command line.. so potentially, provided you have an activated dvdfab license on your pc and I packed in all the required programs, I could make a fully automated one-click tool again where you just pick one of your uhd bd backups, and it makes you a single layer dv mp4 with the full original hd-audio retained.
I've mostly gotten everything to work except atmos to pcm conversions, not getting any audio playing through the shield. Testing on my Pc with VLC is already yielding the same result.
i play DV-files with my LG C9 player, i'm good with only dts-sound. there is in my situation no need to use dvdfab i suppose?Grencola wrote: ↑Sun Dec 22, 2019 5:11 amMy tool just uses dolbymp4muxer which just takes a dual layer m2ts / mkv and makes it mp4. it doesn't combine the layers like dvdfab does, that's proprietary tech which hasn't been reversed engineered yet. but I did notice dvdfab.exe works from a command line.. so potentially, provided you have an activated dvdfab license on your pc and I packed in all the required programs, I could make a fully automated one-click tool again where you just pick one of your uhd bd backups, and it makes you a single layer dv mp4 with the full original hd-audio retained.
Thanks. So does the manual solution now enable the single layer approach to work with object oriented audio? Sorry I'm sure this is somewhere in the thread. It would make sense to have a header post on page one summarising what is possible with links to appropriate pages for more info. Failing that a summary post anywhere in this thread.DaMacFunkin wrote: ↑Sun Dec 22, 2019 8:09 amIf you mean a file that is HDR10 and DV you can’t, the Shield only supports Single layer DV files, the resulting file will not then playback in a player that only supports HDR10.
Regards.
I cant figure out why i cant play my dv single layer mp4s in MXPlayer on 2019 Shield, if i only use dvdfab and copy sound and nothing more, they work, but not if i merge them with mp4box (dts+chapters+dvdfab video)
Does it work for others?
And how can i achieve this yusesoplayer? Do i then sideload it somehow?
mx player doesn't officially support dts and dolby digital audio, so you need to load a custom codec. see here for explanation: https://www.guidingtech.com/37749/mx-player-no-audio/ there's also an xda link to the codec file, the mx_tegra3.zip should be the one for the shield I'd imagine.box4m wrote: ↑Sun Dec 22, 2019 6:56 pmI cant figure out why i cant play my dv single layer mp4s in MXPlayer on 2019 Shield, if i only use dvdfab and copy sound and nothing more, they work, but not if i merge them with mp4box (dts+chapters+dvdfab video)
I installed codecpack and got the whole "restart to install" process, i get sound but a black image and triggers HDR10Grencola wrote: ↑Sun Dec 22, 2019 9:14 pmmx player doesn't officially support dts and dolby digital audio, so you need to load a custom codec. see here for explanation: https://www.guidingtech.com/37749/mx-player-no-audio/ there's also an xda link to the codec file, the mx_tegra3.zip should be the one for the shield I'd imagine.box4m wrote: ↑Sun Dec 22, 2019 6:56 pmI cant figure out why i cant play my dv single layer mp4s in MXPlayer on 2019 Shield, if i only use dvdfab and copy sound and nothing more, they work, but not if i merge them with mp4box (dts+chapters+dvdfab video)
Does anyone know for sure what architecture the 2019 shield is? x86,x86_64,tegra2,tegra3,neon,neon64/ARMv8 ?
it says right on the site I linked:
To know which platform codecs your device will support, open the MX Player Settings and navigate to the option Decoder. Here, navigate to the bottom of the page and you will find an option that says Custom Codec. You can find the type of codec you must download and use here. If you don’t want to go through all this trouble, there’s an all-in-one pack as well.
				technoobmaster
Earlier you said that playing a single layer dolby vision mp4 with atmos using yuseoplayer seems to be stuck on 60FPS, but it seems if I run the same file with mx player and the codecs yuseo provided it runs at 24fps on my shield. Is this correct or am I missing something?Grencola wrote: ↑Mon Dec 23, 2019 7:35 pmit says right on the site I linked:To know which platform codecs your device will support, open the MX Player Settings and navigate to the option Decoder. Here, navigate to the bottom of the page and you will find an option that says Custom Codec. You can find the type of codec you must download and use here. If you don’t want to go through all this trouble, there’s an all-in-one pack as well.
whoa really? that's cool. I don't have a new shield to test it, but mx player on the fire tv stick 4k didn't do frame switching. I doubt the codec makes a difference but I'll try yusesopes with it and see.technoobmaster wrote: ↑Mon Dec 23, 2019 8:15 pmEarlier you said that playing a single layer dolby vision mp4 with atmos using yuseoplayer seems to be stuck on 60FPS, but it seems if I run the same file with mx player and the codecs yuseo provided it runs at 24fps on my shield. Is this correct or am I missing something?
				technoobmaster
It doesnt show atmos on my AVR but it def plays sound and atmos is the only audio track
				DaMacFunkin
Mmm that’s interesting, I’ve demuxed Atmos sound with FFmpeg as per the guide a few pages back, I’ve always thought something isn’t right as Mediainfo can’t correctly identify the stream as TrueHD/Atmos, just MBLA.technoobmaster wrote: ↑Mon Dec 23, 2019 9:16 pmIt doesnt show atmos on my AVR but it def plays sound and atmos is the only audio track
Subsequently when muxed back in with MP4box the stream is still not identified as THD.
is there a difference between DV-mp4 and original DV with the eye? has anyone tested yet?
