The volume key is unknown for this disc...
maiks
Post by maiks » Fri Dec 20, 2019 10:41 am
I copied a complete BR to disk without problems, but still run in problems:
MakeMKV v1.14.7 win(x64-release) started
Opening files on harddrive at D:/Media/Video/6sense
Saved AACS dump file as D:/Media/Video/MKB_v9_unkn0wn_3552.tgz
Any ideas?
Thx
maiks
AACS dump
(177.59 KiB) Downloaded 571 times
Re: The volume key is unknown for this disc...
Post by MartyMcNuts » Fri Dec 20, 2019 10:16 pm
maiks wrote: Fri Dec 20, 2019 10:41 am I copied a complete BR to disk without problems, but still run in problems:
Any ideas?
Thx
maiks
I'm not sure what you mean by the first sentence. It sounds like you have dragged the folders from the disc to your hard drive?
You cannot just copy the folders off an encrypted disc to your hard drive and then try to decrypt that.
MakeMKV uses the disc as it's source so it can get the volumeID and calculate the decryption keys.
