Abominable 4k/Blu Ray/Digital - Volume Key Unknown
PredatorVI
Post by PredatorVI »
UPC: 191329094297
Log file sent (hopefully the right one)
Re: Abominable 4k/Blu Ray/Digital - Volume Key Unknown
If it was the file listed in the lower window, with a file name that starts with MKB2 and ends in .tgz, it should be the right one.
rdgrimes
Post by rdgrimes »
Still not working here. Dump file sent, USA BB purchase.
PredatorVI
I was able to rip it, but am unable to play it. The audio seems to work but playing on WIndows using the latest VLC or via Plex using my NVidia Shield results in either black screen (no video on VLC) or garbled video (Plex).
Anyone else seeing issues after being able to convert it?
I should note that I ripped it twice using two different drives.
Does your playback support decoding h.265 video at the required bandwidth? The Shield should, if the network bandwidth is there. But broken video is common when the network speed can't keep up.
PredatorVI
I think I have at least eliminated an issue. I had a codec pack that installed for one of the media players that was causing VLC to not work correctly. I uninstalled that codec pack as well as did a fresh removal/re-install of VLC and it worked.
I then uninstalled Norton anti-virus and reripped and it's playing fine on both. Sorry for the false error.
-J
Krawk
Post by Krawk »
K-Lite Codec pack and MPC-HC (which is installed with K-Lite) is the best combination to play just about EVERYTHING.
