ASUS BW-16D1HT Installation for Mac Question
bigmack3000
#1 Post by bigmack3000 » Wed Dec 18, 2019 7:03 pm
I want to pick up this player so I can rip uhd discs to emby. However I have a mac desktop and no tower to put the drive in. Can I leave it out on my desk? If not, what do i need? Thanks.
st4evr
Re: ASUS BW-16D1HT Installation for Mac Question
#2 Post by st4evr » Wed Dec 18, 2019 7:36 pm
First, reminder that UHD drives are discussed in this forum:
https://www.makemkv.com/forum/viewforum.php?f=16
you just posted in the UHD discs forum.
Second, read the sticky guide located here:
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
It provides recommended enclosures compatible with what you are asking to do. Read the stickies/guides across the forum. They will often provide answers to these common questions.
bigmack3000
#3 Post by bigmack3000 » Thu Dec 19, 2019 12:55 am
Oops, sorry about that. Is there a way to move it into UHD Drives?
Also, it seems I'll have to flash the drive. Is that possible from a mac? I downloaded one of the firmware packs to see whats inside, and it seems to only have a .exe file.
st4evr
#4 Post by st4evr » Thu Dec 19, 2019 1:39 am
The admin has been notified and he may eventually move it.
There is apparently a non-public (work in progress?) advanced method that may allow you to flash in macOS. See the following discussion and contact "mike admin" if interested and comfortable with command line (heed his warning in that thread):
https://www.makemkv.com/forum/viewtopic ... 068#p82068
Otherwise, you'll need a Windows PC or at the very least a Windows VM within your macOS environment.
Unibrowser
#5 Post by Unibrowser » Sat Dec 21, 2019 1:59 am
bigmack3000 wrote: Thu Dec 19, 2019 12:55 am Oops, sorry about that. Is there a way to move it into UHD Drives?
You can buy the drive on newegg from "cloner alliance". They flash the 3.0 firmware before shipping the drive
This is the way
#6 Post by Billycar11 » Sat Dec 21, 2019 2:55 am
Unibrowser wrote: Sat Dec 21, 2019 1:59 am
for $30+ shipping more than me i bet they don't even test it like i do.i wouldn't recommend buying from them i know these drives have about a 25% fail rate right out of the factory my drives never leave if they are getting read errors. i test with at least 2 disks 1 dual layer and 1 triple layer sometimes more
there is a whole section here about: https://www.makemkv.com/forum/viewforum.php?f=20
my selling post: https://www.makemkv.com/forum/viewtopic ... 20&t=17831
BlueMac77
#7 Post by BlueMac77 » Sun Dec 22, 2019 8:49 am
bigmack3000 wrote: Wed Dec 18, 2019 7:03 pm I want to pick up this player so I can rip uhd discs to emby. However I have a mac desktop and no tower to put the drive in. Can I leave it out on my desk? If not, what do i need? Thanks.
I can confirm the Asus BW-16D1HT blu-ray drive works perfectly on Mac OSX. Best set up is as an external blu-ray drive. You can get the OWC optical drive ext enclosure or the Vantec NexStar ext enclosure, both offers USB 3.0
OWC Enclosure
Vantec Enclosure
There are members here that offer Ready to Use UHD-Friendly Asus drives
If you’re in Australia
https://www.makemkv.com/forum/viewtopic ... 20&t=18747
Unibrowser
#8 Post by Unibrowser » Tue Dec 24, 2019 8:01 pm
Billycar11 wrote: Sat Dec 21, 2019 2:55 am
Didn't know anyone here sold them. Bought mine last year works perfect. I even flashed the modified 3.10 fw which fixed the drive sleep issue. I may be in the market for another drive soon, ill hit you up then
This is the way
bigmack3000
#9 Post by bigmack3000 » Sat Jan 11, 2020 5:56 am
Ok, I picked up the Asus drive and the nexstar enclosure. Here is the information when I plug it into my mac:
Screen Shot 2020-01-11 at 12.51.43 AM.png (58.56 KiB) Viewed 31219 times
I saw in the main thread that if it's 3.10 I need to sidegrade before flashing? What are the steps to do that? I have access to a cheap laptop with windows, if it'll be easier to do on there.
#10 Post by MartyMcNuts » Sat Jan 11, 2020 6:26 am
bigmack3000 wrote: Sat Jan 11, 2020 5:56 am Ok, I picked up the Asus drive and the nexstar enclosure. Here is the information when I plug it into my mac:
No side-grading needed. Just flash directly to 3.10-MK using the windows PC.
bigmack3000
#11 Post by bigmack3000 » Sun Jan 12, 2020 7:38 pm
So am I still doing the first half of this youtube video?
https://www.youtube.com/watch?v=Yfpf6HoMMis
But instead of choosing a file from the download link in the video, I choose file "ASUS-BW-16D1HT-3.10-WM01601-211901041014" from this link?:
https://www.makemkv.com/forum/viewtopic ... 19&t=19113
Do I have this right?
#12 Post by MartyMcNuts » Sun Jan 12, 2020 11:51 pm
bigmack3000 wrote: Sun Jan 12, 2020 7:38 pm So am I still doing the first half of this youtube video?
That video is a bit old now. I'm not sure if the LG flasher works with 3.10 firmware.
The easiest way is to download the modified ASUS flasher + firmware packs from https://www.makemkv.com/forum/viewtopic ... 16&t=18933. There is a mediafire.com download link in the first post.
Run the ASUS flasher on your windows PC and select the ASUS-BW-16D1HT-3.10-WM01601-211901041014 firmware.
