Abominable 4k/Blu Ray/Digital - Volume Key Unknown
PredatorVI
#1 Post by PredatorVI » Wed Dec 18, 2019 4:14 am
UPC: 191329094297
Log file sent (hopefully the right one)
Re: Abominable 4k/Blu Ray/Digital - Volume Key Unknown
#2 Post by Woodstock » Wed Dec 18, 2019 4:20 pm
If it was the file listed in the lower window, with a file name that starts with MKB2 and ends in .tgz, it should be the right one.
rdgrimes
#3 Post by rdgrimes » Thu Dec 19, 2019 7:19 pm
Still not working here. Dump file sent, USA BB purchase.
PredatorVI
#4 Post by PredatorVI » Mon Dec 23, 2019 12:45 am
I was able to rip it, but am unable to play it. The audio seems to work but playing on WIndows using the latest VLC or via Plex using my NVidia Shield results in either black screen (no video on VLC) or garbled video (Plex).
Anyone else seeing issues after being able to convert it?
I should note that I ripped it twice using two different drives.
#5 Post by Woodstock » Mon Dec 23, 2019 1:49 am
Does your playback support decoding h.265 video at the required bandwidth? The Shield should, if the network bandwidth is there. But broken video is common when the network speed can't keep up.
PredatorVI
#6 Post by PredatorVI » Thu Dec 26, 2019 12:12 am
I think I have at least eliminated an issue. I had a codec pack that installed for one of the media players that was causing VLC to not work correctly. I uninstalled that codec pack as well as did a fresh removal/re-install of VLC and it worked.
I then uninstalled Norton anti-virus and reripped and it's playing fine on both. Sorry for the false error.
-J
Krawk
#7 Post by Krawk » Sun Dec 29, 2019 10:08 pm
K-Lite Codec pack and MPC-HC (which is installed with K-Lite) is the best combination to play just about EVERYTHING.
