Download the modified ASUS flasher + firmware pack from https://www.makemkv.com/forum/viewtopic ... 16&t=18933 and try the BU40N firmware in the MK folder. There are a few different BU40N firmwares, including a U101-MK in there. That might help you.Un-carolo wrote: Tue Dec 17, 2019 2:56 pm Hi,
I have a Archgon MD-8102S-U3-BDRW since a week. I try to read blu ray disc UHD with makekv but without success, after +/- 15 sec I have the message 'no disc' (that's the same problem with windows, Ubuntu on a pc and Ubuntu on a notebook. Here are the infos of the drive :
Informations lecteur
Nom du lecteur SE : E:
Fabricant : HL-DT-ST
Produit : BD-RE BU40N
Révision : U100
Numéro de série : MZUJ3TJ0802
Date micrologiciel : 2118-10-23 11:29
Marqueurs d'encryptage bus : 1F
Version AACS la plus haute : 63
Aucun disque (no disc).
My request is perhaps at the wrong place.
I searched in the forum but there is so much informations that I don't know where to look.
The revision has a strange name in comparison with what I found.
Can somebody help me ?
UHD (Official) Friendly Drive - Archgon MD-8107S-U3-UHD (Powered by LG BU40N)
Re: UHD (Official) Friendly Drive - Archgon MD-8107S-U3-UHD (Powered by LG BU40N)
Thanks for this solution.
After verification, I found a problem. The seller (via Amazon) sent me the MD-8102S-U3-BDRW (which does not read UHD blu ray) instead of the MD-8107S-U3-UHD. I am waiting for a solution from the seller.
The supplier sent me the right model MD-8107S-U3-UHD. Here is the info:
Révision : 1.01
Numéro de série : MOFJ7AI3246
Date micrologiciel : 2117-12-22 12:21
Harware support: Yes
Firmware support: No
Firmware version: 1.01
No disc
I downloaded (Modified) ASUS ODD FW Changer (24.08.2019) + UHD Friendly Firmwares + Latest MK Pack but I don't know which is the right firmware among these (there is no one with revision 1.00) :
BU40N-B-Japan-Buffalo : HL-DT-ST-BD-RE_BU40N-BN11-0M00300-211711201351 or HL-DT-ST-BD-RE_BU40N-BU12-OM01001-211902230922
BU40N-FR : HL-DT-ST-BD-RE_BU40N-FR07-JM02202-211801221536
BU40N-N : HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934
BU40N-R-Taiwan : HL-DT-ST-BD-RE_BU40N-1.01-RM00000-211712221221
Bu40N-U : HL-DT-ST-BD-RE_BU40N-U101-MM01201-211711301153.
I have an other question. Is it possible to take a copy of the current firmware before the replacement ?
Révision : 1.01
No disc
None of those. Go back out of the MK folder. The file you are looking for is DE_LG_BU40N_1.00 and is located where the flasher is.Un-carolo wrote: Sun Dec 29, 2019 6:32 pm Hello,
Révision : 1.01
No disc
No, you are not able to backup the firmware (unless you try using the old dosflash method).
Just wanted to give a big THANKS to this thread! Ordered a Archgon from Amazon (USA) and the flasher worked like a champ, using the DE_LG_BU40N_1.00 firmware as directed above. What a great community!
I did the firmware update with "DE_LG_BU40N_1.00" without problem. 4K Blu-ray ripping works flawlessly. Many thanks for this wonderful work.
kingston12
Has anyone successfully used this drive with the USB-C lead that is supplied with it?
I connected it to my iMac this way and it worked fine at first, but now it powers the drive, but it won't read discs.
When I swap back to the standard USB lead it works fine.
It's not a massive problem, but more convenient to leave the drive permanently connected to USB-C if I can.
My bluray drive is failing and I am thinking of getting the Archgon even though I have no 4K disks to date. I figure I should future proof myself. As to the flashing or this drive, can this be done on macOS or do you have to do it through Windows?
The flashers only work on windows.BritGuy wrote: Sun Mar 22, 2020 3:12 am My bluray drive is failing and I am thinking of getting the Archgon even though I have no 4K disks to date. I figure I should future proof myself. As to the flashing or this drive, can this be done on macOS or do you have to do it through Windows?
Not all of them.
if you're ok with command line then makemkv can flash the firmware.
if you're ok with command line then makemkv can flash the firmware. Sent from my SM-G975U using Tapatalk
How long is the flashing supposed to take? Mine is going on about 10 minutes.
10 secondsschiebs wrote: Fri Apr 03, 2020 10:25 pm How long is the flashing supposed to take? Mine is going on about 10 minutes.
If it is taking longer than 10 seconds, do we close the flasher and try again?
ps. Hi and thanks.
ps. Hi and thanks.
I think mine worked, gonna test it out later. thanks everyone.
Sorry if this is a dumb question where can i find the BU40N 1.00 firmware for the archgon MD-8107S-U3-UHD?
thanks!
thanks!
