Star Trek: The Original Series
Has anyone ripped this successfully?  Purchased the complete series new off Amazon and was able to rip all episodes off the first disk (albeit very slowly) but the next 3 disks I've tried keep throwing up errors all over the place and failing to save several of the titles (with no apparent pattern to which ones will rip and which won't). Let me know if anyone has any suggestions or else I'll just request an exchange from Amazon and hope it was just some kind of authoring issue, etc. with this particular set.
Debug log for the last attempt at Season 1 Disk 2 below. Thanks.
MakeMKV v1.14.7 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Jim/MakeMKV_log.txt
Using LibreDrive mode (v05 id=F0ED16432FAA)
File 00000.mpls (angle 1) was added as title #0
File 00000.mpls (angle 2) was added as title #1
File 00001.mpls (angle 1) was added as title #2
File 00001.mpls (angle 2) was added as title #3
File 00002.mpls (angle 1) was added as title #4
File 00002.mpls (angle 2) was added as title #5
File 00003.mpls (angle 1) was added as title #6
File 00003.mpls (angle 2) was added as title #7
Title #00009.mpls has length of 127 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00017.mpls has length of 10 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00018.mpls has length of 10 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00019.mpls has length of 10 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00016.mpls has length of 10 seconds which is less than minimum title length of 600 seconds and was therefore skipped
File 00010.mpls (angle 1) was added as title #8
File 00010.mpls (angle 2) was added as title #9
Title #00011.mpls has length of 222 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00160.m2ts has length of 63 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00161.m2ts has length of 63 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00162.m2ts has length of 63 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00163.m2ts has length of 63 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00165.m2ts has length of 67 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00166.m2ts has length of 60 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00169.m2ts has length of 17 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00173.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00175.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00180.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00184.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00186.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00190.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00203.m2ts has length of 8 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00170.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00171.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00002.m2ts has length of 63 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00155.m2ts has length of 221 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00156.m2ts has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Saving 5 titles into directory D:/Rips/Star Trek S1
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00109.m2ts' at offset '390328320'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '390328320'
DEBUG: Code 3221225628 at ]8PztK'0td`)P05'q8:29394758
DEBUG: Code 100864261 at ]8PztK'0td`)P05'q8:29394758
DEBUG: Code 0 at 0#09wVinY17cV#\_v,qo:29395011
DEBUG: Code 0 at N.*jR!M0zLg3p,94*?XT:29394068
DEBUG: Code 0 at 0#09wVinY17cV#\_v,qo:29394459
DEBUG: Code 190590 at 0#09wVinY17cV#\_v,qo:29393286
DEBUG: Code 0 at a\;2X|KY0-z5BQ^r{QzKS:213136608
DEBUG: Code 0 at %3VSbJFKJLZK[g`ZAr$M:29394022
DEBUG: Code 0 at 3&OMB,U"{xm(-d{$+Cx:121264648
DEBUG: Code 0 at %3VSbJFKJLZK[g`ZAr$M:29404257
DEBUG: Code 0 at %3VSbJFKJLZK[g`ZAr$M:29404763
DEBUG: Code 0 at %3VSbJFKJLZK[g`ZAr$M:213139759
DEBUG: Code 0 at *~hnCI|G[w/I^^d}:29395908
DEBUG: Code 0 at %\#Rf#g+*H<yf9zBe:213132698
DEBUG: Code 0 at %\#Rf#g+*H<yf9zBe:213132146
DEBUG: Code 0 at %\#Rf#g+*H<yf9zBe:29393769
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 0 to file D:/Rips/Star Trek S1/Star Trek Season 1- Disc 2_t00.mkv
DEBUG: Code 0 at r.i/6:;$931$jo0Oh:213135389
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00152.m2ts' at offset '0'
DEBUG: Code 0 at N.*jR!M0zLg3p,94*?XT:29397610
DEBUG: Code 0 at 0#09wVinY17cV#\_v,qo:213130145
DEBUG: Code 0 at 0#09wVinY17cV#\_v,qo:121262233
DEBUG: Code 0 at 0#09wVinY17cV#\_v,qo:29393286
DEBUG: Code 0 at a\;2X|KY0-z5BQ^r{QzKS:213136332
DEBUG: Code 0 at a\;2X|KY0-z5BQ^r{QzKS:213136240
DEBUG: Code 18 at L=]cBSSM.Ur4BBJ[YVh:121264004
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00151.m2ts' at offset '14284800'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '14284800'
DEBUG: Code 6975 at 0#09wVinY17cV#\_v,qo:29393286
DEBUG: Code 0 at %3VSbJFKJLZK[g`ZAr$M:213134860
Failed to save title 4 to file D:/Rips/Star Trek S1/Star Trek Season 1- Disc 2_t04.mkv
Encountered 27 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
3 titles saved, 2 failed
I ripped it.  Likely a bad set and you’ll want to replace but you can clean each disc with soft cloth in case they have residue/film on them.
You likely already know this but one angle is original in space special effects and other angel is new high def versions. I went for new versions as I’m not that much a purest.
Re: Star Trek: The Original Series
Thanks. I always wipe disks (new or old) before I put them in the drive to rip and these all appear to be legit new and pristine. (A few Amazon reviews mentioned getting loose disks or ones with the odd fingerprint or light scratch, suggesting they weren't actually even though they were wrapped and sold that way, but I don't think that's the case here). Anyway, I'll do the exchange and cross my fingers the replacement set works better.hart2hart wrote: ↑Sun Dec 15, 2019 7:02 pmI ripped it. Likely a bad set and you’ll want to replace but you can clean each disc with soft cloth in case they have residue/film on them.
I did figure out the angle 1 vs 2 thing but thanks for mentioning it. Funny, I'd read about the original vs. enhanced effects and was sure I'd be a purist about it but as soon as I saw the difference in the opening seconds of a few episodes I'm now totally sold on the enhanced. One other thing I was wondering though: were you able to get the picture in picture commentary on the "Starfleet Access" extras to work when watching on disk? I understand MakeMKV can't rip the PiP so I didn't expect it to work in the MKVs but for me even watching on disk (on an LG UHD player), you see the talking heads in the bottom right corner but there's no way to switch the audio to their commentary. MakeMKV shows it as a DTS Express Stereo track in the fragments that still come up with my minimum 10 min title settings but the track doesn't play anything in MKV either (maybe because those are just segments between the PiP?). Anyway, I can live without it but it's just weird to me that they don't even work right when watching on a regular bluray player.
Wait a minute, MakeMKV can too rip PiP because I ripped a commentary track like that from the Glory UHD. So now I'm even more confused. Anyway, on with the return.
Hopefully, it’s not a bad batch of discs. I’ve gone through as many as 3 set before just getting refund and going to another vendor.ElJimador wrote:Thanks. I always wipe disks (new or old) before I put them in the drive to rip and these all appear to be legit new and pristine. (A few Amazon reviews mentioned getting loose disks or ones with the odd fingerprint or light scratch, suggesting they weren't actually even though they were wrapped and sold that way, but I don't think that's the case here). Anyway, I'll do the exchange and cross my fingers the replacement set works better.hart2hart wrote: ↑Sun Dec 15, 2019 7:02 pmI ripped it. Likely a bad set and you’ll want to replace but you can clean each disc with soft cloth in case they have residue/film on them.
I didn’t attempt to play them in a regular player to see the PiP features. Maybe I’ll pull them out of basement storage and try it out. I’ve got a Sony Player and PowerDVD to test with.
Good luck.
				ITgreybeard
Do you hear nothing from the audio stream?  I have found that DTS Express tracks are sometimes sparse in the audio delivered; that is to say that there will be large audio dead zones with the occasional live zone. In my novice experience, I have found the DTS Express track to be used for occasional commentary, where there is otherwise no sound at all. MPC-HC is my player.
									Customized Dell T7400 Workstation: dual 3GHz quad xeons; 112GB dram; raid 0 ssd system "disk"; nvme temp "disk"; multiple 750GB-2TB work disks; multiple 4TB external USB3 storage disks; dual HP 1080p monitors. It's old but so am i!
I just bought this set. Would you happen to remember which angle has the new effects?hart2hart wrote: ↑Sun Dec 15, 2019 7:02 pmI ripped it. Likely a bad set and you’ll want to replace but you can clean each disc with soft cloth in case they have residue/film on them.
Also, I noticed the video didn't look quite as good as it could, so I think I'll see what I can do to clean it up in Handbrake. Which Handbrake settings would you recommend? In particular, would you recommend sharpening or denoising? Which levels?
It’s been at least a couple years so I don’t recall the angle. I’d just pull same playlist with angle 1 and then 2 to compare. It stays the same throughout the discs.Faber wrote:I just bought this set. Would you happen to remember which angle has the new effects?hart2hart wrote: ↑Sun Dec 15, 2019 7:02 pmI ripped it. Likely a bad set and you’ll want to replace but you can clean each disc with soft cloth in case they have residue/film on them.
Agree video could be cleaner but I didn’t sharpen or denoise it. Since it’s a scan of older film stock with its grain, my experience has been that additional post processing never gets better for me. Let me know if you find a good combination.
I just bought Magnum PI on BluRay. It looks much better than it did on DVD but has some of same video issues you’re seeing. I think it’s just best that can be done with older film stock (intended only for 480i scan) scans while keeping price reasonable.
Magnum PI on BD does not include subtitles so I’m in process of ripping DVD sub/idx them from my DVD MKV files, converting to SUP with scaling, and merging results into the HD MKV. Developed a command line workflow builder in Excel to create .bat files. Only troublesome variable is setting Delay time to sync subtitle to video and audio. -1250ms worked for first 5 episodes but episode 6 was -2900ms. Hopefully a reasonable pattern applies. I know that the show intro changed between episodes 11 and 12. If it’ll at least be same for each season.
I've been having an issue with a disc from the second season. I'm giving it another try at the moment, but it looks like the disc has a weird circular scratch which is likely causing the issue. Does CBS have some sort of disc replacement program? Or might I have to exchange the whole set?hart2hart wrote: ↑Sun Dec 15, 2019 7:02 pmI ripped it. Likely a bad set and you’ll want to replace but you can clean each disc with soft cloth in case they have residue/film on them.
You likely already know this but one angle is original in space special effects and other angle is new high def versions. I went for new versions as I’m not that much a purest.
Faber wrote:I've been having an issue with a disc from the second season. I'm giving it another try at the moment, but it looks like the disc has a weird circular scratch which is likely causing the issue. Does CBS have some sort of disc replacement program? Or might I have to exchange the whole set?hart2hart wrote: ↑Sun Dec 15, 2019 7:02 pmI ripped it. Likely a bad set and you’ll want to replace but you can clean each disc with soft cloth in case they have residue/film on them.
Never heard of anyone getting a replacement disc but you can try. More likely you’ll have exchange the set. If so, I’d rip all you can from this set to minimize having issue with different disc.
I couldn't tell from this post which angle is the "enhanced"? Is it angle 1?ElJimador wrote: ↑Mon Dec 16, 2019 1:08 amThanks. I always wipe disks (new or old) before I put them in the drive to rip and these all appear to be legit new and pristine. (A few Amazon reviews mentioned getting loose disks or ones with the odd fingerprint or light scratch, suggesting they weren't actually even though they were wrapped and sold that way, but I don't think that's the case here). Anyway, I'll do the exchange and cross my fingers the replacement set works better.hart2hart wrote: ↑Sun Dec 15, 2019 7:02 pmI ripped it. Likely a bad set and you’ll want to replace but you can clean each disc with soft cloth in case they have residue/film on them.
Ages ago now. Rip angle 1 and if it doesn’t strike you as upgraded then it’s angle 2. You’ll know when you see it.lujan wrote:I couldn't tell from this post which angle is the "enhanced"? Is it angle 1?ElJimador wrote: ↑Mon Dec 16, 2019 1:08 amThanks. I always wipe disks (new or old) before I put them in the drive to rip and these all appear to be legit new and pristine. (A few Amazon reviews mentioned getting loose disks or ones with the odd fingerprint or light scratch, suggesting they weren't actually even though they were wrapped and sold that way, but I don't think that's the case here). Anyway, I'll do the exchange and cross my fingers the replacement set works better.hart2hart wrote: ↑Sun Dec 15, 2019 7:02 pmI ripped it. Likely a bad set and you’ll want to replace but you can clean each disc with soft cloth in case they have residue/film on them.
for anyone who happens to come across this in the future, i've just started ripping this set, Angle 1= Remaster, Angle 2= Originalhart2hart wrote: ↑Mon Jun 27, 2022 1:20 amAges ago now. Rip angle 1 and if it doesn’t strike you as upgraded then it’s angle 2. You’ll know when you see it.lujan wrote:I couldn't tell from this post which angle is the "enhanced"? Is it angle 1?ElJimador wrote: ↑Mon Dec 16, 2019 1:08 am
hope this helps!
