Cars
Nagrom
Cars
#1 Post by Nagrom » Mon Oct 11, 2010 5:34 am
I'm assuming 1.6.0 just has some bugs, but I am trying to rip Cars and it is not working at all.
MakeMKV v1.6.0 win(x64-release) started
Evaluation version, 26 day(s) out of 30 remaining
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00060.m2ts' at offset '13961312256'
File 00052.mpls was added as title #0
Title #00024.mpls has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00072.mpls is equal to title 00052.mpls and was skipped
Title 00074.mpls is equal to title 00052.mpls and was skipped
Title #00011.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00036.m2ts was added as title #1
File 00037.m2ts was added as title #2
File 00038.m2ts was added as title #3
File 00039.m2ts was added as title #4
File 00040.m2ts was added as title #5
File 00041.m2ts was added as title #6
File 00042.m2ts was added as title #7
File 00043.m2ts was added as title #8
File 00044.m2ts was added as title #9
File 00045.m2ts was added as title #10
File 00046.m2ts was added as title #11
File 00047.m2ts was added as title #12
Title #00048.m2ts has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00049.m2ts was added as title #13
Title #00050.m2ts has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00051.m2ts was added as title #14
Title #00052.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00053.m2ts was added as title #15
Title #00054.m2ts has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00055.m2ts was added as title #16
Title #00057.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00058.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00059.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.m2ts has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00120.m2ts was added as title #17
Title #00121.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory D:/Videos
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00060.m2ts' at offset '3198222336'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00060.m2ts' at offset '3198744576'
Failed to save title 0 to file D:/Videos/title00.mkv
0 titles saved, 1 failed
Re: Cars
#2 Post by mike admin » Wed Oct 13, 2010 8:52 am
Nagrom wrote: Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00060.m2ts' at offset '3198744576'
It's a physically scratched disc.
