ctwins95
Post by ctwins95 »
ragico wrote:
Mon Nov 04, 2019 2:58 pm
FusionNeo wrote:
Mon Nov 04, 2019 4:38 am
@yusesope, just to give you an update, the file plays back but only in HDR. It seems the Dolby Vision support for the Shield is only profile 5 like the other streamers out on the market.
I also tried the file on Amazon Firestick 4K (which supports DV single layer profile 5 through emby) and it plays in HDR.
Just to let @yusesope to know about.
Hi guys, I'm new here and can say I really appreciate all the work done and shared ;)
To let you know the file dvhe.04.06 is correctly detected and played as DoVi on my LG E6 tv (dlna streaming).
By the way, I'm trying to generate single layer DV mp4 files with DVDFab (11.0.6.0), and for all of them, but Alita, just get green pictures as reported else where (First Man, BumbleBee, Despicable Me 2, Downsizing, Gladiator, Mortal Engines).
I remark that the first hevc stream for Alita is :
"SMPTE ST 2094 App 4, Version 1, HDR10+ Profile A compatible"
and the others are :
"SMPTE ST 2086, HDR10 compatible"
So a question to @yuseope, as your samples (seem to) come from Hellboy, is it like Alita, or others, and in this second case, what version of DVDFab do you use ? (as all work well on my tv)
Thank you !
s0074 wrote:
Fri Dec 13, 2019 4:24 pm
Does anybody know what Dolby's Microsoft Store app Dolby Vision Extensions is for?
Looks like it adds support for DV on Netflix but it doesn't trigger DV on my TV. :( same for the single or dual layer file played in Movies and TV app.
Image Image
Grencola
Post by Grencola »
RESET_9999 wrote:
Sat Dec 14, 2019 1:16 am
Image Image
from that dolby page:
<<This application requires Dolby Vision licensed device.
* Please restart Dolby Access after installing Dolby Vision Extensions.>>
daddy
Post by daddy »
anhlong1910 wrote:
Thu Dec 12, 2019 7:28 am
daddy wrote:
Tue Dec 10, 2019 6:43 am
step by step instruction to build a mp4 with dual layer dv from a multi m2ts disc like Gladiator.
https://www.makemkv.com/forum/viewtopic ... 820#p76820
I'm sorry but I got stuck at step 3 and I have no idea of what he was trying to instruct.
Could you please be more specific what software do I need to download to work with this DolbyVision-muxing here maybe I can try figure out on my own if I know what to download
you need
- ffmpeg => https://ffmpeg.zeranoe.com/builds/
- mp4muxer => https://github.com/DolbyLaboratories/dl ... master/bin
- mp4box => https://gpac.wp.imt.fr/downloads/gpac-nightly-builds/
The easyest way is to install all those command line tools in the same folder.
kazuma
Post by kazuma »
grencola, i have a question for you. can you make your dv-mp4-maker tool for turkish audio?
Grencola
Post by Grencola »
kazuma wrote:
Mon Dec 16, 2019 6:57 pm
just use the one I made that let's you pick whatever audio track you want: https://bit.ly/38Mbv6U
kazuma
Post by kazuma »
Grencola wrote:
Mon Dec 16, 2019 8:39 pm
ah thnx! this program is still the best way to watch movies in DV i suppose? are there any updates from you?
Merlyn6175
Post by Merlyn6175 »
Been messing with yusesope player for the Amazon Fire TV, and I'm getting mixed results, I know it a work in progress.
all films have been converted to Dolby Vision single stream with DVDFab (passthrough), all audio is AC3 or EAC3.
I found all the Audio tracks work fine, All video streams kick in to Dolby Vision Mode (LG C7) but some videos play and some have black screens.
Transformers no Picture
James Bond casino Royale works fine.
I've tried it with Web optimiser on and off as I'm not sure what it does.
will try none passthrough mode on a few tonight.
Are people getting the same thing with the New Nvidia Shield?
agentreza
Post by agentreza »
I was finally able to get quite a few rips working, DTS HD/ DTS X works great but atmos converted to PCM 7.1 using ffmpeg does not play any any audio? Anybody with a shield tv Pro got a PCM 7.1 track to work using the Plex beta player? AC3 track works in the same video.
saxonjackson
Post by saxonjackson »
agentreza wrote:
Wed Dec 18, 2019 5:33 am
I got several working with converting Atmos to PCM 7.1 and playing on Plex with 2019 Shield. I'm having better results using Plex's legacy player (in the Plex app advanced settings). I also have several that do not work, from both DTS:X and Atmos-to-PCM conversions. The titles that don't work give a black screen but usually the play audio.
box4m
Post by box4m »
So theres aloooot of information being thrown around here, awesome job guys :)
Did anyone manage to put TrueHD into mp4 together with dvdfab single layer DV file?
anhlong1910
Post by anhlong1910 »
daddy wrote:
Sat Dec 14, 2019 11:43 am
you need
Thank you so much folks,
I will try and be back later.
jesper1994
Post by jesper1994 »
box4m wrote:
Wed Dec 18, 2019 6:33 pm
Yes!
https://forum.mrmc.tv/viewtopic.php?f=1 ... 425#p25425 here you can find all the information!
DaMacFunkin
Post by DaMacFunkin »
jesper1994 wrote:
Thu Dec 19, 2019 9:05 am
Yes!
Yes? We know you can do that but there are no readily available players / devices that can play the resulting files.
box4m
Post by box4m »
So ive been looking for a sustainable way (and the family have special needs, zoom for example lol) to playback dolby vision mp4s for like 6months now, this thread makes me so happy, you are the best.
For some reason i didnt try MX Player until yesterday, and wow, simple/fast
The issue/question i have is.
It plays dolby vision with HW decoder if i play a certain chapter from Atomic Blonde, from USB-attached.
If i play Atomic Blonde the whole movie from SMB share, it says "hw decoder not available" or something, what goes? You would do me the biggest favour if u have a solution or guidance :(
edit: All made with DVDFab / ffmpeg / mp4box DTS into DVDFab single layer DV
edit again: Some files play, will investigate why some are not
