Step-by-step guide for the best (IMHO) drive: LG WH16NS60
Locked
mgadbois
Re: Step-by-step guide for the best (IMHO) drive: LG WH16NS60
#46 Post by mgadbois » Sat Nov 02, 2019 9:30 pm
Thanks for the feedback. I appreciate the response.
DVD Maniac
#47 Post by DVD Maniac » Fri Nov 08, 2019 7:26 pm
Thanks for the post. Have never used one of these because they are not available in UK, well only at extortionate prices on Amazon. Can I ask what you pay in US?
mgadbois
#48 Post by mgadbois » Fri Nov 08, 2019 7:27 pm
$104.
markymark
#49 Post by markymark » Fri Nov 15, 2019 12:55 am
@tragic bleak,
Thanks so much for your guide and updating it. Following your suggestion and this guide.
I bought the LG WH16NS60, it came with fw 1.02. I had it installed and ripping in one of my UHD Blu rays in 15 minutes.
Thanks again for your time and effort in creating this guide.
Mark.
mgadbois
#50 Post by mgadbois » Fri Nov 15, 2019 2:29 am
I must be doing something wrong because it takes me 40 or so minutes to RIP a 4K UHD disk now. I am curious how you got the speed so fast.
#51 Post by Billycar11 » Fri Nov 15, 2019 2:35 am
mgadbois wrote: Fri Nov 15, 2019 2:29 am I must be doing something wrong because it takes me 40 or so minutes to RIP a 4K UHD disk now. I am curious how you got the speed so fast.
40 mins is normal for a 66 GB disk 100GB discs 60 mins
i think he means he was setup and flashed in 15 mins
mgadbois
#52 Post by mgadbois » Fri Nov 15, 2019 2:49 am
Thanks for the information. I didn't know those numbers before.
markymark
#53 Post by markymark » Fri Nov 15, 2019 6:50 pm
Yes Billy is correct. 15 min to install and flash the drive. I ripped a UHD disk successfully. It did take around 40 minutes.
omk1980
#54 Post by omk1980 » Sat Dec 14, 2019 4:43 am
So i have a LG WH16NS60. I flashed it in august 2019 to v1.01 that is libre drive enabled. Should i flash to 1.02mk? i've been getting a lot of disc read errors as of late and not sure if upgrading firmware will allow for a better ripping experience.
#55 Post by Billycar11 » Sat Dec 14, 2019 4:51 am
omk1980 wrote: Sat Dec 14, 2019 4:43 am So i have a LG WH16NS60. I flashed it in august 2019 to v1.01 that is libre drive enabled. Should i flash to 1.02mk? i've been getting a lot of disc read errors as of late and not sure if upgrading firmware will allow for a better ripping experience.
not going to help anything a bad disk is a bad disk a bad drive is a bad drive what you have i dont know
omk1980
#56 Post by omk1980 » Sat Dec 14, 2019 5:02 am
Billycar11 wrote: Sat Dec 14, 2019 4:51 am
Hoping it's a bad disk. Can't get fury but was able to get Spider-Man 2002 today on same drive.
My question is does 1.02mk offer any advantages to my 1.01? Uhd playback isn't too important to me.
#57 Post by Billycar11 » Sat Dec 14, 2019 5:07 am
omk1980 wrote: Sat Dec 14, 2019 5:02 am
i know of no advantages lg does not post patch notes or even the firmware itself
omk1980
#58 Post by omk1980 » Sat Dec 14, 2019 5:36 am
Billycar11 wrote: Sat Dec 14, 2019 5:07 am
Thank you. I'll leave it alone then.
BBreeziN
#59 Post by BBreeziN » Thu Jan 02, 2020 8:46 pm
Question for the experts here, I just bought a WH16NS60 that was manufactured on 20191029. It came with 1.02 firmware. I flashed the 1.02 MK firmware according to these instructions. At 100%, I got a message that said "Update Failed The drive may will be emergency mode This mode is allowed only F/W flash Sense 00/00/00".
I rebooted, and my drive appears to be working fine, and MakeMKV shows it as LibreDrive enabled. Am I good to go? Was this error harmless? Thanks for the all the work collecting this information in one place and the help!
#60 Post by Billycar11 » Fri Jan 03, 2020 2:48 am
BBreeziN wrote: Thu Jan 02, 2020 8:46 pm Question for the experts here, I just bought a WH16NS60 that was manufactured on 20191029. It came with 1.02 firmware. I flashed the 1.02 MK firmware according to these instructions. At 100%, I got a message that said "Update Failed The drive may will be emergency mode This mode is allowed only F/W flash Sense 00/00/00".
Harmless some sata controllers are weird same with the USB to sata converters
Locked
