The Office Season 6 Disc 3
gonoles9
#1 Post by gonoles9 » Mon Oct 11, 2010 2:32 am
Fails to rip 3 of the episodes immediately. Here is the debug log:
MakeMKV v1.6.0 win(x86-release) started
Debug logging enabled, log will be saved as C:\MakeMKV_log.txt
Opening files on harddrive at F:/THE_OFFICE_S6D3/VIDEO_TS/
Calculated BUP offset does not match one in IFO header.
Cells 5-end were skipped due to cell commands (structure protection?)
Title #0 was added (4 cell(s), 0:22:04)
Title #1 was added (5 cell(s), 0:29:41)
Title #2 was added (22 cell(s), 2:11:24)
Title #3 was added (4 cell(s), 0:22:04)
Title #4 was added (5 cell(s), 0:22:08)
Title #5 was added (5 cell(s), 0:22:05)
Cells 6-end were skipped due to cell commands (structure protection?)
Title #6 was added (5 cell(s), 0:22:05)
Title #7 was added (4 cell(s), 0:43:03)
Title #8 was added (4 cell(s), 0:43:03)
Cells 2-end were skipped due to cell commands (structure protection?)
Title #9 was added (1 cell(s), 0:02:50)
Title #10 was added (1 cell(s), 0:09:17)
Title #11 was added (1 cell(s), 0:10:22)
Cells 7-end were skipped due to cell commands (structure protection?)
Title #12 was added (6 cell(s), 0:22:36)
Title #13 was added (1 cell(s), 0:02:50)
Title #14 was added (1 cell(s), 0:09:17)
Title #15 was added (1 cell(s), 0:10:22)
Title #16 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 4 in VTS 1 is equal to title 1 and was skipped
Title 9 in VTS 1 is equal to title 8 and was skipped
Title 5 in VTS 2 is equal to title 1 and was skipped
Title 6 in VTS 2 is equal to title 2 and was skipped
Title 7 in VTS 2 is equal to title 3 and was skipped
Saving 10 titles into directory F:/Video/DRMP_3_6_3
Title 0 skipped
DEBUG: Code 0 at T.g'OyG"}$?mfYyd3n=jW:213130490
DEBUG: Code 0 at T.g'OyG"}$?mfYyd3n=jW:213129639
DEBUG: Code 0 at ^m.0&P3(7X$IY\$JhQ@:29394183
DEBUG: Code 0 at mbekjYvz,FE4*_>|AuF:29394160
DEBUG: Code 0 at mbekjYvz,FE4*_>|AuF:29395195
Failed to save title 1 to file F:/Video/DRMP_3_6_3/title01.mkv
Failed to save title 3 to file F:/Video/DRMP_3_6_3/title03.mkv
Failed to save title 4 to file F:/Video/DRMP_3_6_3/title04.mkv
Title 5 skipped
Title 6 skipped
Title 7 skipped
Title 8 skipped
Title 9 skipped
Title 10 skipped
0 titles saved, 3 failed
Re: The Office Season 6 Disc 3
#2 Post by mike admin » Wed Oct 13, 2010 9:01 am
Known error in 1.6.0, will be corrected very soon.
