Feature Request: Disable automatic disk scan
Dude69
#1 Post by Dude69 » Fri Oct 05, 2012 6:24 pm
I often use my DVD drive for ripping disks, it takes a long time. Same time I might fire up MakeMKV to work no images. Problem is, MakeMKV will always automatically scan the disk drive. It not only interrupts the process but also delays me using MakeMKV. Thanks for considering this option.
doveplay
Re: Feature Request: Disable automatic disk scan
#2 Post by doveplay » Wed Oct 24, 2012 5:44 pm
I vote for this with a small clarification: The scanning (what is automatic today) and analysis (which requires an action today) should be configurable such that one can toggle automatic mode for both.
anomousny
#3 Post by anomousny » Tue Nov 13, 2012 3:06 am
+1
For my typical usage the automatic disk scan is useless and makes me wait every time I start MakeMKV.
joe42
#4 Post by joe42 » Wed Nov 14, 2012 9:31 pm
I too would like to have an option to disable the automatic disc scan.
rinza
#5 Post by rinza » Thu Dec 12, 2019 11:05 pm
Please add this feature. I use other tools to work with physical media, with MakeMKV working almost exclusively with ISO files. MakeMKV's automatic behaviour causes seek conflicts, disrupting the other program.
How I currently workaround this problem:
I have a dummy ISO file that I mount as a virtual drive. I have MakeMKV's "single drive" mode enabled, and tell it to use the virtual drive when it opens.
It would be nice to just have a checkbox in the MakeMKV config to disable that behaviour instead of deflecting unwanted behaviour with a hack.
kolepard
#6 Post by kolepard » Sun Apr 26, 2020 4:14 pm
I too would like to see an option to disable automatic disc scanning.
Thank you for considering this feature.
Kevin
#7 Post by Billycar11 » Sun Apr 26, 2020 11:10 pm
Turn on exclusive drive mode/ single drive mode
#8 Post by Woodstock » Mon Apr 27, 2020 12:51 pm
Exclusive mode won't work for this, because the goal is to go directly to ripping images on the hard drive. Exclusive mode just limits how many drives are "inconvenienced" getting there.
paulster
#9 Post by paulster » Fri May 01, 2020 11:24 pm
Adding a +1 for this. I rip everything to ISO first and since I have two drives if I get a 2-disc set then I can't start MakeMKV until the second ISO has finished ripping or it can cause problems with the drive that's active.
mtc3882
#10 Post by mtc3882 » Mon Apr 11, 2022 10:04 pm
And a +1 from me too. The automatic DVD drive scan when I start makemkv is a nuisance and adds unnecessary delay. I only use makemkv to convert already-ripped DVDs which are stored on a hard drive. It's okay if auto-scan is the default when makemkv is downloaded, but I'd like to be able to change that behaviour on a permanent basis.
magingen
#11 Post by magingen » Tue Nov 08, 2022 6:46 pm
It's been 10 years and this is still an issue. How hard can it be to add something like this?
#12 Post by Billycar11 » Tue Nov 08, 2022 9:31 pm
It's not an issue turn on single drive mode in settings
goldenvenom
#13 Post by goldenvenom » Fri Apr 04, 2025 8:07 am
Hi, a bit late coming back for this topic, i even asked AI to collerct info but there is no hit.
Enabling "single drive mode" won't avoid loading the drive automatically.
proc-mkv1-> rip uhd
proc-mkv2-> convert to .mkv
ptoc-mkv2 loads the drive that mkv1 uses which slows it down a lot until it found it just to open a bbmv. Am i missing something to archieve this behaviour?
Greetings
#14 Post by dcoke22 » Sat Apr 05, 2025 1:42 pm
proc-mkv1-> rip uhd
Greetings
When you create the second MakeMKV process, the one I think you're using to load a backup and create .mkv files from it, are you selecting a different optical drive than the one you selected when you created the first MakeMKV process?
