Are there any other TL discs out there. I've use this drive for several backups so far and haven't run into this issue before.MartyMcNuts wrote: Thu Dec 12, 2019 5:59 amI think SamuriHL is right.omk1980 wrote: Thu Dec 12, 2019 4:48 am No difference. Here's the Log.
MakeMKV v1.14.7 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\kolon/MakeMKV_log.txt
Backing up disc into folder "C:/Users/kolon/Desktop/Converted/FURY"
Using LibreDrive mode (v05 id=6E4B09EE276C)
DEBUG: Code 100864261 at ]8PztK'0td`)P05'q8:213131778
DEBUG: Code 100864261 at ]8PztK'0td`)P05'q8:121261934
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.01' at offset '33368965120'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.fmts' at offset '30333272064'
DEBUG: Code 0 at D*/=gn5bNdDk\[KRmG{:121266189
DEBUG: Code 0 at D*/=gn5bNdDk\[KRmG{:213133365
DEBUG: Code 0 at GX&i4=RmBuPBlUA1:gU :29396920
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Backup failed
It looks like the drive is having trouble reading Fury as it's a TL disc. Both my external NS60 and BP60NB10 have trouble with TL discs. When that happens, I use my trusty old BH16NS55! Still going strong after 2 years!!
"Fury" error
omk1980
Re: "Fury" error
Re: "Fury" error
https://forum.blu-ray.com/showthread.php?t=294596omk1980 wrote: Thu Dec 12, 2019 9:09 am
i have seen many defective drives some read bd 100 great and the same drive one will get read errors on a bd 66 does not make sense to me but whatever.
my normal steps are
clean disk
get new disk
a step most people can't do but i do is check it in a known good drive because i always have at least 3 around
clean drive
get new drive
Re: "Fury" error
I've only ever had trouble with some of the larger TL discs. Usually if they are >80GB. Fury is about 90GB.omk1980 wrote: Thu Dec 12, 2019 9:09 amAre there any other TL discs out there. I've use this drive for several backups so far and haven't run into this issue before.MartyMcNuts wrote: Thu Dec 12, 2019 5:59 amI think SamuriHL is right.omk1980 wrote: Thu Dec 12, 2019 4:48 am No difference. Here's the Log.
Backup failed
omk1980
Re: "Fury" error
Thanks for the link. I have quite a few of those discs backed up via my external. I'll try to get another fury disc.Billycar11 wrote: Thu Dec 12, 2019 9:38 amhttps://forum.blu-ray.com/showthread.php?t=294596omk1980 wrote: Thu Dec 12, 2019 9:09 am
my normal steps are
clean disk
get new disk
clean drive
get new drive
In the meantime, I dont have a dedicated desktop to throw my LG drive in but am putting together an unraid server. They do have a makemkv docker, I believe. Hopefully it's updated to have aacs 2.1 decryption.
