Can't rip Crimes of Grindelwald UHD (purchased in UK)
Get error The volume key is unknown for this disc - video can't be decrypted
Log file uploaded.
I can decrypt other UHD discs fine.
Anydvd can't handle this disc either.
Fantastic beasts the crimes of grindelwald UHD DUMP
Re: Fantastic beasts the crimes of grindelwald UHD DUMP
- MKB20_v66_Fantastic_Beasts-_The_Crimes_of_Grindelwald_B11D.tgz
- (176.93 KiB) Downloaded 604 times
Posting the dump in the forum gets you nowhere. You have to submit data dump to the developer for proper support as he is the only one that can use that data dump to add support. How? Forum search function works. Use it to find solutions to common questions and avoid delays in support and potential headaches.rjnichols wrote: Wed Dec 11, 2019 9:33 am Can't rip Crimes of Grindelwald UHD (purchased in UK)
Log file uploaded.
https://www.makemkv.com/forum/search.ph ... n+for+this
What to do is also discussed in the first page of this very post/thread.
And this is not AnyDVD support, they have their own support forum. There is nothing that can be done here for AnyDVD UHD BD support.
