Once upon a time in Hollywood
charlie62
Post by charlie62 »
Not working for me,it seems to record about a third then the time keeps climbing but nothing new is recorded. I stopped it at 23 17. Unfortunately my pc is in bits so I can't send a file to support.
Re: Once upon a time in Hollywood
Others have ripped it, so some description of what errors you're seeing would help.
Trakter
Post by Trakter »
I too am having trouble with it. I was getting the issue saying it was unable to decrypt it.
zltful
Post by zltful »
Not sure if this user is getting the same as I am, but it appears that I am not able to decrypt...
MakeMKV v1.14.7 win(x64-release) started
Using LibreDrive mode (v05 id=76A0C3CD522E)
Saved AACS dump file as C:\Users\Administrator/.MakeMKV/MKB20_v68_Once_Upon_a_Time_in_Hollywood_6444.tgz
Dump is attached...
(3.3 MiB) Downloaded 1245 times
charlie62
Post by charlie62 »
Working now, I think it had something to do with it being 3 layer
wschmitt55
Post by wschmitt55 »
zltful wrote: Wed Dec 11, 2019 12:15 am Not sure if this user is getting the same as I am, but it appears that I am not able to decrypt...
Dump is attached...
Same problem here. Video can't be decrypted, failed to open disc.
Post by SamuriHL »
If you're getting a message that the title can't be decrypted, you need to send the log to svq at makemkv dot com. Posting it here won't help. Once Mike receives them, he usually gets them added fairly quick, but, it sometimes can take a few days. I get this title delivered tomorrow.
zltful
Post by zltful »
Sent the dump file to Mike.
Thanks, SamuriHL for the heads up.
vercetti757
Post by vercetti757 »
I wanted to post here for anyone else with the same copies, i was able to successfully decrypt and rip my copies of Once Upon A Time In Hollywood. I tested the Collectors Edition and also the Best Buy USA Steelbook versions.
Post by SamuriHL »
I was also able to rip the collector's edition with no problem.
TheShoe
Post by TheShoe »
Interesting!
Once Upon a Time In Hollywood will not load on my official UHD drive - LG WH16NS60 firmware 1.00. MakeMKV can’t find the disc
On an older “friendly drive”, it works. But it also reports AACS as “AACS 2.0/C v68”, which I don’t recall ever seeing the “/C” before.
Being this is a Sony title, and Sony seems to be hell-bent on thwarting this type of thing, wonder if the “/C” which Mike talks about is incompatible with some UHD drives without a firmware update.
Or it’s my setup... Anyone else notice similar? Note the disc seems to be ripping on the older drive but is slower than usual at only 2.6X
Post by SamuriHL »
TheShoe
Post by TheShoe »
yup read that. was more curious why one drive failed to even mount this disc while an older “friendly” drive had no issues.
Post by SamuriHL »
That's just the nature of uhd. It's why I have 2 drives in my machine. When one doesn't like a particular disc, the other usually reads it. Most of the time anyway.
