X-Men First Class
dvdplayer
X-Men First Class
Post by dvdplayer » Wed May 29, 2019 10:40 am
Hi all,
I've tried to decrypt a backup of X-Men First Class and it keeps failing with debug code 8704. Would this be a disc issue?
Attached are the logs.
Thank you.
Re: X-Men First Class
Post by Woodstock » Wed May 29, 2019 1:32 pm
003006:0000 Opening files on harddrive at C:/Users/Justin/Desktop/X-Men.First.Class.2011.2160p.BluRay.HEVC.DTS-HD.MA.5.1-NOGRP
003305:0000 AACS directory not present, assuming unencrypted disc
If the backup is still encrypted, MakeMKV needs either the key for it, or the information necessary to get the key. If the backup were done with MakeMKV, the information necessary to decrypt it would be in the backup directory. If it was NOT done with MakeMKV, you will need the original disk to create the file needed.
dvdplayer
Post by dvdplayer » Fri May 31, 2019 5:36 am
00800.mpls was the problem, 00801.mpls was fine and so was 00802.mpls
MiKeeVid
Post by MiKeeVid » Mon Dec 09, 2019 1:58 pm
Any idea what the difference is between the 3 different playlists? Which one is "the right one"?
Title information
Source file name: 00800.mpls
Duration: 2:11:42
Chapters count: 32
Segment count: 7
Segment map: 6,61,68,69,71,66,76
Title information
Name: X-Men First Class (2011) [4k] - Version 801 (English)
Source file name: 00801.mpls
Duration: 2:11:42
Chapters count: 32
Segment count: 7
Segment map: 6,61,63,69,70,66,92
Title information
Name: X-Men First Class (2011) [4k] - Version 802 (English)
Source file name: 00802.mpls
Duration: 2:11:42
Chapters count: 32
Segment count: 7
Segment map: 6,61,68,69,71,66,67
Post by Woodstock » Mon Dec 09, 2019 2:42 pm
The language displayed in the title and credits, and possibly other shots that involve text. For American releases, they would be English, Spanish, and French.
MiKeeVid
Post by MiKeeVid » Tue Dec 10, 2019 6:42 pm
Thank you!
EnochLight
Post by EnochLight » Wed Sep 04, 2024 12:51 am
I know this is an old thread, but I just had to chime in and thank you for this. I'm doing a backup of my First Class UHD Blu-ray, and these 3 playlists were throwing me for a loop as well. Cheers mate!
