I have an Archgon 8107 series drive with the 1.01 firmware. Today I tried to do my first UHD rip, and it failed spectacularly.
I've read several threads that indicate that I might need to downgrade the firmware on the drive, which will then let MakeMKV access UHD discs. How can I do this on MacOS? I'm happy to use command-line utilities or other Unix-y stuff but will not consider running Windows in a virtual machine or mailing my drive to someone else to perform the downgrade. Is there a solution, or am I out of luck?
Archgon drive with UHD discs
st4evr
Re: Archgon drive with UHD discs
Since the current publicly available flashing utilities required for this are Windows only, then you are out of luck. You are limiting yourself on this.ecormany wrote: Sun Dec 08, 2019 11:02 pm but will not consider running Windows in a virtual machine or mailing my drive to someone else to perform the downgrade. Is there a solution, or am I out of luck?
- Contact:
There is a mac native flasher, but it is relatively low-level in two senses: it is a command-line tool, and at is not fool-proof at all. If you are comfortable with command-line and are confident that you won't flash "something just in case", please PM me and I'll provide instructions. I would need the current information for your drive (what is displayed on the right pane under LibreDrive information).ecormany wrote: Sun Dec 08, 2019 11:02 pm I have an Archgon 8107 series drive with the 1.01 firmware. Today I tried to do my first UHD rip, and it failed spectacularly.
ecormany
Here's the drive info. I'll also PM it separately.
OS device name: /dev/rdisk4
Product: BD-RE BU40N
Revision: 1.01
Serial number: KZFHCCI1437
Firmware date: 2117-12-22 12:21
Bus encryption flags: 1F
Highest AACS version: 63
Harware support: Yes
Firmware support: No
Firmware version: 1.01
Unrestricted read speed: Possible (with patched firmware)-
ecormany
Actually, I can't PM yet because my account is new. Can you initiate that conversation?
- Contact:
Just in case, this in now discussed in detail here - https://www.makemkv.com/forum/viewtopic ... 19&t=21278
