Archgon drive with UHD discs
ecormany
Post by ecormany » Sun Dec 08, 2019 11:02 pm
I have an Archgon 8107 series drive with the 1.01 firmware. Today I tried to do my first UHD rip, and it failed spectacularly.
I've read several threads that indicate that I might need to downgrade the firmware on the drive, which will then let MakeMKV access UHD discs. How can I do this on MacOS? I'm happy to use command-line utilities or other Unix-y stuff but will not consider running Windows in a virtual machine or mailing my drive to someone else to perform the downgrade. Is there a solution, or am I out of luck?
st4evr
Re: Archgon drive with UHD discs
Post by st4evr » Mon Dec 09, 2019 3:40 pm
Since the current publicly available flashing utilities required for this are Windows only, then you are out of luck. You are limiting yourself on this.
Post by mike admin » Mon Dec 09, 2019 8:17 pm
There is a mac native flasher, but it is relatively low-level in two senses: it is a command-line tool, and at is not fool-proof at all. If you are comfortable with command-line and are confident that you won't flash "something just in case", please PM me and I'll provide instructions. I would need the current information for your drive (what is displayed on the right pane under LibreDrive information).
ecormany
Post by ecormany » Mon Dec 09, 2019 10:06 pm
Here's the drive info. I'll also PM it separately.
OS device name: /dev/rdisk4
Product: BD-RE BU40N
Revision: 1.01
Serial number: KZFHCCI1437
Firmware date: 2117-12-22 12:21
Bus encryption flags: 1F
Highest AACS version: 63
Harware support: Yes
Firmware support: No
Firmware version: 1.01
ecormany
Post by ecormany » Tue Dec 10, 2019 4:52 pm
Actually, I can't PM yet because my account is new. Can you initiate that conversation?
Post by mike admin » Fri Feb 14, 2020 10:35 pm
Just in case, this in now discussed in detail here - https://www.makemkv.com/forum/viewtopic ... 19&t=21278
