Sorry for the Noob question, but is MKB mean AACS? I mean, are you saying version 1.14.5, and up have host certificate to handle AACS v72 for drives without libredrve?mike admin wrote: Tue Oct 15, 2019 12:09 pmMKBv72 is currently supported on 1.14.5 with latest key updates.MartyMcNuts wrote: Sun Oct 13, 2019 1:32 am B is correct. Mike added host certificate for v70 so without libredrive you can rip all discs up to and including v70.
Samsung SE 506 info
TheFatWookie
Re: Samsung SE 506 info
Yes
Yes, but the inhibitor to access any disc is the revocation table which blocks programs like MakeMKV from accessing the drive, even if this AACS version xy is supported. Looks like that te new GoT Season 8 discs have a updated revocation table and uses AACS 72. With libredrive, no problem because the revocation table is irrelevant, but without libredrive MakeMKV access to the drive fails.I mean, are you saying version 1.14.5, and up have host certificate to handle AACS v72 for drives without libredrve?
Good Luck
TheFatWookie
OMG now I am really confused. If MakeMKV 1.14.7 has AACS v72 and GoT S8 discs uses AACS v72 revocation table then I thought drives without libredrive would be fine since the key in MakeMKV has been updated to match the latest on the discs. The problem would be if newer discs had a newer table (like v73 or something) until MakeMKV is updated to match.Grauhaar wrote: Mon Dec 09, 2019 1:54 pmYes
In the changlog, I see:
MakeMKV v1.14.4 (6.6.2019 )
Added support for AACS v70 (for those poor souls without LibreDrive)
but for the latest versions, I see no such notation, so it's possible that AACS v72 remains unsupported for "those poor souls without LibreDrive"?:
MakeMKV v1.14.7 (4.12.2019 )
Bug fixes:
Better compatibility for decrypted AACS 2.1 FMTS files
Fixed variable expansion bug for default file name template
MakeMKV v1.14.6 (2.12.2019 )
Added support for AACS 2.1
Many small bugfixes and improvements
Although, I suppose it could be a documentation oversight?
Bug fixes:
Three things must work for rippingTheFatWookie wrote: Mon Dec 09, 2019 4:07 pm then I thought drives without libredrive would be fine since the key in MakeMKV has been updated to match the latest on the discs.
1. The program (f.e. MakeMKV) is not revoked by the revocation table (this is a drive block) in case a drive without libredrive is used. A drive with libredrive support ignores the revocation table.
2. The program (f.e. makeMKV) must support the AACS version xy of the disc
3. The program (f.e. MakeMKV) must construct the key to decrypted the disc content
As you see, the drive (revocation) and the disc (AACS support) and of cource the key for the disc itself are involved.
Good Luck
TheFatWookie
Looking at this exchange:Grauhaar wrote: Mon Dec 09, 2019 4:34 pmThree things must work for rippingTheFatWookie wrote: Mon Dec 09, 2019 4:07 pm then I thought drives without libredrive would be fine since the key in MakeMKV has been updated to match the latest on the discs.
It sounds like I can put a disc with with AACS v70 into my non libredrive drive without fear of MakeMKV 1.14.4 being revoked. It also sounda like I can put AACS v72 discs into my drive without fear of MakeMKV being revoked as long as I am using MakeMKV 1.14.5 or 1.14.7. All I want is confirmation on this.mike admin wrote: Tue Oct 15, 2019 12:09 pmMKBv72 is currently supported on 1.14.5 with latest key updates.MartyMcNuts wrote: Sun Oct 13, 2019 1:32 am B is. Mike added host certificate for v70 so without libredrive you can rip all discs up to and including v70.
Negative Confirmation!It also sounda like I can put AACS v72 discs into my drive without fear of MakeMKV being revoked as long as I am using MakeMKV 1.14.5 or 1.14.7. All I want is confirmation on this.
If you put an AACS v72 disc in your drive it will update the revocation table. If you do not have LibreDrive, MakeMKV will no longer work with that drive. Even old discs you may have ripped before will no longer work.
If you have LibreDrive, it ignores the revocation table and the latest MakeMKV with latest server downloads can rip up to AACS v72.
TheFatWookie
So I can use up to AACS v70 discs per the MakeMKV 1.14.4 release notes. What about this statement from MikeAdmin: "MKBv72 is currently supported on 1.14.5 with latest key updates." or is that referring to something different?jinx100 wrote: Mon Dec 09, 2019 8:33 pmNegative Confirmation!It also sounda like I can put AACS v72 discs into my drive without fear of MakeMKV being revoked as long as I am using MakeMKV 1.14.5 or 1.14.7. All I want is confirmation on this.
The latest version of MakeMKV can decode discs with MKBv72 (AACS v72) but cannot get past the revocation table without LibreDrive. You should take the time to read https://www.makemkv.com/forum/viewtopic ... 19&t=18856So I can use up to AACS v70 discs per the MakeMKV 1.14.4 release notes. What about this statement from MikeAdmin: "MKBv72 is currently supported on 1.14.5 with latest key updates." or is that referring to something different?
TheFatWookie
Thank you thank you. I had read the article on "What is LibreDrive" before but was not getting that the decoding and having a key to get past the revocation were two different things. This brought it home: "The latest version of MakeMKV can decode discs with MKBv72 (AACS v72) but cannot get past the revocation table without LibreDrive". I have noted that MakeMKV seems to get updated periodically so I will need to wait until I see a new release of MakeMKV with release notes: "Added support for AACS v72 (for those poor souls without LibreDrive).... or invest in a libredrive enabled drive as I have seen in the UHD sub forum.jinx100 wrote: Mon Dec 09, 2019 9:30 pmThe latest version of MakeMKV can decode discs with MKBv72 (AACS v72) but cannot get past the revocation table without LibreDrive. You should take the time to read https://www.makemkv.com/forum/viewtopic ... 19&t=18856So I can use up to AACS v70 discs per the MakeMKV 1.14.4 release notes. What about this statement from MikeAdmin: "MKBv72 is currently supported on 1.14.5 with latest key updates." or is that referring to something different?
TheFatWookie
Well. So after much discussion I discovered that the GoT S8 Blu-Ray discs (again NOT the 4K UHD but the 1080p discs) actually only have AACS v68 (at least in my country). I was able to rip them on my non-libredrive Drive just fine with MakeMKV 1.14.7. But thanks for the help/education in learning about libredrive and the whole AACS thing!
frankhedman
I have the Samsung BD-SE506, but I can't play any blu-ray discs on it, Samsung, or TSST (ToshibaSamsungStorageTechnology) that support that drive seems to have gone into liquidation.
There is alot of problems regarding this model, and alot of people is searching for a update, I might have a firmware file that could be able to modify, if someome could help out.
/Frank
/Frank
- Samsung SE-506 AB and SE- 506BB and mounting program.rar
- (2.66 MiB) Downloaded 1706 times
frankhedman
Just to explain my latest post.
The firmware of SE506 combined with Win10 somehow makes it impossible to watch blu-ray movies on a PC, but it is possible to use the drive for CD and DVD.
So I was thinking that there might something in the firmware that could be modified.
If it's hard to modify, shouldn't someone have bought the old TSST manufacturing plant, and still be using firmware similar to TSST. I've read that someone thought that Liteon bought the plant.
If a firmware update on se506 could be made, there is alot of drives out there that could be updated and put to good use again.
are you even using makemkv?frankhedman wrote: Fri Jan 10, 2020 2:25 pm I have the Samsung BD-SE506, but I can't play any blu-ray discs on it, Samsung, or TSST (ToshibaSamsungStorageTechnology) that support that drive seems to have gone into liquidation.
/Frank
makemkv is not primarily used to watch movies but can be if you follow this guide: https://www.makemkv.com/forum/viewtopic ... ibs#p70794
it has nothing to do with firmware you just don't have software to play blurays since your player probably came with player software if you just want to watch movies off the disk
it will be more user friendly then makemkvs libs
frankhedman
I have tried using makemkv, but I couldn’t get it to work with the samsung drive. I have tried using VLC with that method, but no luck so far.
I don’t use the computer for viewing movies, more for making backups.
I think that a updated firmware could make it possible to turn a useless drive (that is cheap in the used market) to a great drive. When I found the original firmware I thought it was worth a shot adding it to this forum that seems to have alot of experts.
Billycar11 wrote: Mon Jan 13, 2020 10:22 amare you even using makemkv?frankhedman wrote: Fri Jan 10, 2020 2:25 pm I have the Samsung BD-SE506, but I can't play any blu-ray discs on it, Samsung, or TSST (ToshibaSamsungStorageTechnology) that support that drive seems to have gone into liquidation.
/Frank
