Dark Knight Rises 4K HDR
pedall
Post by pedall »
Getting this dump when trying to make a MKV.
MakeMKV v1.14.7 win(x64-release) started
Using LibreDrive mode (v05 id=067EFCA8EA7E)
Saved AACS dump file as C:\Users\pedall/.MakeMKV/MKB20_v61_Dark_Knight_Rises_95D3.tgz
(123.69 KiB) Downloaded 562 times
Re: Dark Knight Rises 4K HDR
Post by SamuriHL »
Attaching it here won't help. You need to email that file to svq at makemkv dot com so that Mike can add support for it.
st4evr
Post by st4evr »
Forum search function works. Learn to use it. The steps to take when this occurs have been already discussed thoroughly.
https://www.makemkv.com/forum/search.ph ... is+unknown
