No streaming icon on MakeMKV
Isense
Post by Isense » Sun Dec 08, 2019 5:36 pm
I am using the latest MakeMkv version (v.1.14.7) both windows and linux version . It is registered version. Streaming icon is nowhere to be found. What to do?
Re: No streaming icon on MakeMKV
Post by Woodstock » Sun Dec 08, 2019 6:16 pm
You must have been using a rather old version if you're just noticing that. The streaming button was removed in 1.4.0, and there is a DLL named libmmbd provided for VLC or Kodi to use instead.
Post by d00zah » Sun Dec 08, 2019 6:17 pm
Isense wrote: Sun Dec 08, 2019 5:36 pm I am using the latest MakeMkv version (v.1.14.7) both windows and linux version . It is registered version. Streaming icon is nowhere to be found. What to do?
It was removed (quite) a while back.
From MakeMKV revision history:
MakeMKV v1.14.0 (5.11.2018 )
Obsolete features:
Removed UPNP streaming (Use VLC or Kodi with libmmbd instead)
Linux: Removed mmdtsdec/libdcadec (Use latest ffmpeg instead)
https://www.google.com/search?q=VLC%20l ... irefox-b-1
Isense
Post by Isense » Tue Dec 10, 2019 6:56 pm
Thank you all!
