star wars the last jedi UHD failure (solved)
g00se
Post by g00se » Sun Dec 08, 2019 11:06 am
Problem solved: I updated to 1.14.7, changed from 3.10 MK firmware to DE 3.02 firmware and cleaned the disk with an alcohol wipe and magically I was able to make a backup of the disk.
I just got this disk brand new yesterday, opened the box and put it straight into my drive to read it.
I am getting the following problem and not sure why as I have been able to use the drive for normal blu rays absolutely fine, this is the first UHD disk I have tried however.
Log info below, I Hope you are able to provide some information.
when it gets to the decryption part it takes it a while to parse the following file, not sure if that has any effect?
/AACS/Content000.cer
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number:
Bus encryption flags: 1F
Highest AACS version: 66
Firmware version: 3.10
MakeMKV v1.14.5 win(x64-release) started
The new version 1.14.7 is available for download at http://www.makemkv.com/download/
Using LibreDrive mode (v05 id=0FA242DD4D0B)
Title #00002.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00300.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00004.mpls was added as title #0
File 00801.mpls was added as title #1
File 00800.mpls was added as title #2
Title #00900.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00012.m2ts was added as title #3
File 00011.m2ts was added as title #4
File 00007.m2ts was added as title #5
Title #00014.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00048.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00004.mpls is equal to title 00800.mpls and was skipped
Saving 5 titles into directory D:/Video/The Last Jedi (2017)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00012.m2ts' at offset '26500460544'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26500460544'
Failed to save title 0 to file D:/Video/The Last Jedi (2017)/The Last Jedi_t00.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00012.m2ts' at offset '25812989952'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00012.m2ts' at offset '25813383168'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '25813383168'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00012.m2ts' at offset '25817579520'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '25817579520'
Failed to save title 1 to file D:/Video/The Last Jedi (2017)/The Last Jedi_t01.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00012.m2ts' at offset '24707985408'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '24707985408'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00012.m2ts' at offset '27127443456'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '27127443456'
Failed to save title 2 to file D:/Video/The Last Jedi (2017)/The Last Jedi_t02.mkv
Forced subtitles track #9 turned out to be empty and was removed from output file
Forced subtitles track #11 turned out to be empty and was removed from output file
Encountered 43 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
2 titles saved, 3 failed
The following three parts will not save:
Title information
Name: The Last Jedi
Source file name: 00801.mpls
Duration: 2:31:51
Chapters count: 52
Segment count: 2
Segment map: 11,12
File name: The Last Jedi_t00.mkv
Title information
Name: The Last Jedi
Source file name: 00800.mpls
Duration: 2:31:51
Chapters count: 52
Segment count: 2
Segment map: 7,12
File name: The Last Jedi_t01.mkv
Title information
Name: The Last Jedi
Source file name: 00012.m2ts
Duration: 2:29:45
Segment count: 1
Segment map: 12
File name: The Last Jedi_t02.mkv
The following 2 parts do save:
Title information
Name: The Last Jedi
Source file name: 00011.m2ts
Duration: 0:02:05
Segment count: 1
Segment map: 11
File name: The Last Jedi_t03.mkv
Title information
Name: The Last Jedi
Source file name: 00007.m2ts
Duration: 0:02:05
Segment count: 1
Segment map: 7
File name: The Last Jedi_t04.mkv
I believe this is all of the information I am able to gain from makemkv for problem solving.
Re: star wars the last jedi UHD failure
Post by Woodstock » Sun Dec 08, 2019 2:50 pm
Start by updating to 1.4.7 (current version). That probably won't help, because the error looks to be a section of the disk that the drive cannot read, and it tries VERY HARD to do so... So hard that the operating system thinks it has gone off-line.
g00se
Post by g00se » Sun Dec 08, 2019 3:39 pm
Updated to 1.14.7
I'll try again and see how far I get, I've also flashed my drive with 3.02 with libre instead of MK 3.10, will report back.
g00se
Post by g00se » Sun Dec 08, 2019 4:23 pm
Well I tried again, MakeMKV tried again, but....
MakeMKV v1.14.7 win(x64-release) started
Backing up disc into folder "E:/Video/backup/THE_LAST_JEDI"
Using LibreDrive mode (v05 id=96929CF53B04)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00012.m2ts' at offset '27248099328'
Encountered 6 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Backup failed
Is the ASUS drive I have useless for UHD disks? or is it just this disk? the drive performs absolutely fine on non-UHD blu rays.
Post by SamuriHL » Sun Dec 08, 2019 5:44 pm
Looks like a bad disc. Microfiber clean it and if that doesn't work, you'll need to replace the disc.
g00se
Post by g00se » Mon Dec 09, 2019 11:49 am
Thank you, I don't even understand how but cleaning the brand new disk with a glasses wipe magically made it work even thought there were no humanly visible marks on the disk.
Re: star wars the last jedi UHD failure (solved)
Post by SamuriHL » Mon Dec 09, 2019 12:17 pm
Yeah these discs sometimes ship with an invisible film of oil on them. Highly annoying but a good cleaning usually does the trick.
