[SOLVED] Makemkv suddently does not recognize Blu Rays anymore
Roaster
#1 Post by Roaster » Sun Dec 08, 2019 10:27 am
I updated makemkv to the latest version, makemkv-1.14.7. Before the upgrade, I could watch Blu Rays. After the upgrade it does not recognize the disk anymore. The drive is still recognized. Downgrading does not solve the problem.
Excerpt of cd-drive. Does it matter that Blu Ray is not mentioned in the reading section?
Or could this potentially be a hardware problem?
Profile List Feature
	Blu Ray BD-RE
	Blu Ray BD-R random recording
	Blu Ray BD-R sequential recording
	Blu Ray BD-ROM
	DVD+R Double Layer - DVD Recordable Double Layer
	DVD+R - DVD Recordable
	DVD+RW - DVD Rewritable
	DVD-R - Double-layer Jump Recording
	DVD-R - Double-Layer Sequential Recording
	Re-recordable DVD using Sequential Recording
	Re-recordable DVD using Restricted Overwrite
	Re-writable DVD
	Re-recordable DVD using Sequential recording
	Read only DVD
	CD-RW Re-writable Compact Disc capable
	Write once Compact Disc capable
	Read only Compact Disc capable
Hardware                                  : CD-ROM or DVD
Can eject                                 : Yes
Can close tray                            : Yes
Can disable manual eject                  : Yes
Can select juke-box disc                  : No
Can set drive speed                       : No
Can read multiple sessions (e.g. PhotoCD) : Yes
Can hard reset device                     : Yes
Reading....
  Can read Mode 2 Form 1                  : Yes
  Can read Mode 2 Form 2                  : Yes
  Can read (S)VCD (i.e. Mode 2 Form 1/2)  : Yes
  Can read C2 Errors                      : Yes
  Can read IRSC                           : Yes
  Can read Media Channel Number (or UPC)  : Yes
  Can play audio                          : Yes
  Can read CD-DA                          : Yes
  Can read CD-R                           : Yes
  Can read CD-RW                          : Yes
  Can read DVD-ROM                        : Yes
Re: Makemkv suddently does not recognize Blu Rays anymore
#2 Post by Woodstock » Sun Dec 08, 2019 2:35 pm
By "watch BDs", are you referring to using MakeMKV to allow player software to read BDs "on the fly", without ripping them first?
Roaster
#3 Post by Roaster » Sat May 16, 2020 7:53 am
The Bluray drive was broken. I got another one and it worked again! Thanks for helping.
