What is the recommended external UHD drive for use with a AIO desktop?
verzzano
Post by verzzano » Fri Dec 06, 2019 12:31 pm
Is it also better to go with an enclosure with a internal drive inside it or external?
Re: What is the recommended external UHD drive for use with a AIO desktop?
Post by Woodstock » Fri Dec 06, 2019 1:29 pm
The recommendation for "all-in-one" PC desktops is the same as for all-in-one Macs - Internal plus a compatible enclosure. That gives the best flexibility and speed.
Slim USB drives can run in to power problems and generate errors.
verzzano
Post by verzzano » Sun Dec 08, 2019 11:13 am
Woodstock wrote: Fri Dec 06, 2019 1:29 pm The recommendation for "all-in-one" PC desktops is the same as for all-in-one Macs - Internal plus a compatible enclosure. That gives the best flexibility and speed.
I appreciate the reply, thanks.
DVD Maniac
Post by DVD Maniac » Mon Dec 09, 2019 8:03 pm
In terms of price / performance combination my recommendation is ASUS BW-16D1HT or (only slightly slower) BC-12D2HT coupled with an adapter rather than an enclosure. You can still of course install the drive direct SATA but my tests show very little drop in performance via USB 3.0 and of course its far more flexible.
Post by Coopervid » Mon Dec 09, 2019 10:09 pm
It's pretty tough these days to find a good enclosure for a 5,25" drive. I also suggest to get an USB3 adapter. Depends on the region what is available. In Europe I suggest the Sharkoon Drive Link Combo U3 V2.
