[SOLVED] Makemkv suddently does not recognize Blu Rays anymore
Roaster
Post by Roaster »
I updated makemkv to the latest version, makemkv-1.14.7. Before the upgrade, I could watch Blu Rays. After the upgrade it does not recognize the disk anymore. The drive is still recognized. Downgrading does not solve the problem.
Excerpt of cd-drive. Does it matter that Blu Ray is not mentioned in the reading section?
Or could this potentially be a hardware problem?
Profile List Feature
	Blu Ray BD-RE
	Blu Ray BD-R random recording
	Blu Ray BD-R sequential recording
	Blu Ray BD-ROM
	DVD+R Double Layer - DVD Recordable Double Layer
	DVD+R - DVD Recordable
	DVD+RW - DVD Rewritable
	DVD-R - Double-layer Jump Recording
	DVD-R - Double-Layer Sequential Recording
	Re-recordable DVD using Sequential Recording
	Re-recordable DVD using Restricted Overwrite
	Re-writable DVD
	Re-recordable DVD using Sequential recording
	Read only DVD
	CD-RW Re-writable Compact Disc capable
	Write once Compact Disc capable
	Read only Compact Disc capable
Hardware                                  : CD-ROM or DVD
Can eject                                 : Yes
Can close tray                            : Yes
Can disable manual eject                  : Yes
Can select juke-box disc                  : No
Can set drive speed                       : No
Can read multiple sessions (e.g. PhotoCD) : Yes
Can hard reset device                     : Yes
Reading....
  Can read Mode 2 Form 1                  : Yes
  Can read Mode 2 Form 2                  : Yes
  Can read (S)VCD (i.e. Mode 2 Form 1/2)  : Yes
  Can read C2 Errors                      : Yes
  Can read IRSC                           : Yes
  Can read Media Channel Number (or UPC)  : Yes
  Can play audio                          : Yes
  Can read CD-DA                          : Yes
  Can read CD-R                           : Yes
  Can read CD-RW                          : Yes
  Can read DVD-ROM                        : Yes
Re: Makemkv suddently does not recognize Blu Rays anymore
By "watch BDs", are you referring to using MakeMKV to allow player software to read BDs "on the fly", without ripping them first?
Roaster
Post by Roaster »
The Bluray drive was broken. I got another one and it worked again! Thanks for helping.
