AACS 2.1 support
Re: AACS 2.1 support
Post by Coopervid » Sat Dec 07, 2019 9:48 pm
What? If I start Makemkv it always scans the drive...
hernanez
Post by hernanez » Sat Dec 07, 2019 9:49 pm
mike admin wrote: Sat Dec 07, 2019 9:28 pm Do I understand the key points from workflow:
- get the (unsupported) disc
- backup it into "protected whatever" format (iso, files, etc) - you get ~70GB "bundle #1"
- put the disc on a shelf
- the moment disc is supported, decrypt the "protected whatever" into decrypted folder structure (with whatever tool now supports this disc) - this is "bundle #2"
- delete still encrypted "bundle #1" forever
- use some tools (MakeMKV , handbrake or anything) with "bundle #2"
Specifically, am I correct to assume that the protected/encrypted backup lives only until it could be converted into decrypted folder structure, being the most universal "source" format. Right?
There is no real use for the encrypted folder once you decrypted. At least I don't think there is.
Some people like having the whole disc structure rather than save economic stripped MKVs. Like if you want to play it with something that supports menus etc (PDVD?)
hernanez
Post by hernanez » Sat Dec 07, 2019 9:50 pm
Coopervid wrote: Sat Dec 07, 2019 9:48 pm What? If I start Makemkv it always scans the drive...
It scans the drives to see if there is anything loaded, but it doesn't process the disc, e.g hash check etc.
Post by d00zah » Sat Dec 07, 2019 9:52 pm
Coopervid wrote: Sat Dec 07, 2019 9:34 pm Mike,
you are right.
I still don't get why SamuriHL thinks I'm wrong. Thinking about it I think that I just assumed that the drive is UHD friendly / supported by Libre Drive. Maybe that's his point.
SamuriHL wrote: Fri Dec 06, 2019 11:52 pm That method is wrong. Just loading makemkv and doing nothing will in fact do nothing. The disc has to be scanned.
mike admin wrote: Sat Dec 07, 2019 9:22 pm
Coopervid wrote: Sat Dec 07, 2019 9:10 pmCookbook please...
You have to see the message "Using LibreDrive mode" one way or another.
That msg will be part of the MakeMKV output AFTER a disc has been successfully scanned.
Post by Coopervid » Sat Dec 07, 2019 9:55 pm
So what? It can't process the disc since the protection is not supported. You mean I have to try that, it fails and only then I can create a protected ISO. That doesn't make sense.
Therefore: Cook book please
jayper
Post by jayper » Sat Dec 07, 2019 10:09 pm
hernanez wrote: Sat Dec 07, 2019 9:49 pm
Definitely, with regular BRs, I like to open them in PowerDVD for special features occasionally.
With UHD discs, I will occasionally load up the entire folder structure so that I can watch a movie with Dolby Vision.
Post by d00zah » Sat Dec 07, 2019 10:14 pm
Coopervid wrote: Sat Dec 07, 2019 8:59 pm If there is an unsupported disc using AACS2.1
Load disc
Start Makemkv (close AnyDVD before, if active?)
Don't do anything further with Makemkv
At this point, the disc must have been scanned by Makemkv & the drive put in 'LibreDrive' mode in order to successfully perform a RAW read of the encrypted data (with the other tool, to decrypt at a later date). Pretty sure this is the part you keep missing & SamuriHL is trying to correct. Could be wrong... wouldn't be the 1st time.
Coopervid wrote: Sat Dec 07, 2019 8:59 pm Create protected backup ISO with either Imgburn or Daemon tools
Wait until any program supports this disc
Load ISO with e.g. VirtualCloneDrive
Process virtual disc from ISO with program that now supports this disc
hernanez
Post by hernanez » Sat Dec 07, 2019 10:15 pm
jayper wrote: Sat Dec 07, 2019 10:09 pm Definitely, with regular BRs, I like to open them in PowerDVD for special features occasionally.
Oh yeah, good point on DV support in Full discs, forgot about that. There are some players that can do that (Oppo I think is one). You lose that option with mkvs sadly.
Post by Coopervid » Sat Dec 07, 2019 10:18 pm
Yes, I also do full folders to put it on my M9702 media player and I don't convert to MKV for that reason.
Still need the cook book and I don't mind if you call me idiot and mean this is self-explanatory.
flashback8
Post by flashback8 » Sun Dec 08, 2019 12:39 am
Hi. First off, thanks to Mike for the support! Looking forward to picking up some AACS 2.1 discs now. :) I do have a question about the way that the support works. As I recall, there was a post where Mike simplified the concept of AACS 2.1. It had to do with some frames having alternate versions included, and all the frames being usable by the studios to determine which keys were used to pick up those frames and create rips. (I may have gotten some of that wrong but that's the gist, as I recall.) I'm assuming that there's a "correct" frame and that MakeMKV not only knows how to pick up that frame but also mask how it gets to that point. Am I correct? Just curious.
Thanks again!
Post by SamuriHL » Sun Dec 08, 2019 1:12 am
SamuriHL wrote: Sat Dec 07, 2019 6:46 pmBeing able to specify an ISO image to convert to unprotected folder backup would make my life SO much easier. Alternatively doing the same from an encrypted folder backup would also work for me.
For me, that's correct. It might not be for Teddy as I don't know if he keeps the protected ISO around. For me you've got it exactly.
Post by SamuriHL » Sun Dec 08, 2019 1:14 am
No, it doesn't enable LibreDrive mode just starting MakeMKV. You have to click on the drive icon and THEN you will see the message in the log window that "LibreDrive enabled". Until then, it won't work. Period.
Post by SamuriHL » Sun Dec 08, 2019 1:15 am
Coopervid wrote: Sat Dec 07, 2019 9:55 pm So what? It can't process the disc since the protection is not supported. You mean I have to try that, it fails and only then I can create a protected ISO. That doesn't make sense.
I doesn't make any sense to you, yes. But you MUST enable LibreDrive mode regardless of whether it can decrypt the disc in order for it to disable bus encryption on the drive. Otherwise the protected ISO is pretty near useless.
Post by SamuriHL » Sun Dec 08, 2019 1:17 am
d00zah wrote: Sat Dec 07, 2019 10:14 pm
Load disc
Correct, sir. Exactly what I'm trying to get across.
Post by d00zah » Sun Dec 08, 2019 3:05 am
SamuriHL wrote: Sun Dec 08, 2019 1:17 am Correct, sir. Exactly what I'm trying to get across.
Phew! :o
