Updated to 1.14.7, but it keeps making my Mac restart
kingston12
Has anyone else had the problem? When I run 1.14.7, it actually crashes my Mac. It automatically restarts, but then just crashes again when I launch MakeMKV.
Re: Updated to 1.14.7, but it keeps making my Mac restart
The Mac should be logging what's crashing it. Do you have the system log event?
kingston12
This is what it says:Woodstock wrote: Sat Dec 07, 2019 1:51 am The Mac should be logging what's crashing it. Do you have the system log event?
*** Panic Report ***
panic(cpu 0 caller 0xffffff8012a06ee6): "mount_common(): mount of udf filesystem failed with 6, but vnode list is not empty."@/BuildRoot/Library/Caches/com.apple.xbs/Sources/xnu/xnu-4903.278.12/bsd/vfs/vfs_syscalls.c:1154
Backtrace (CPU 0), Frame : Return Address
0xffffff82f5ffb620 : 0xffffff80127af57d
0xffffff82f5ffb670 : 0xffffff80128eb065
0xffffff82f5ffb6b0 : 0xffffff80128dc79a
0xffffff82f5ffb720 : 0xffffff801275c9d0
0xffffff82f5ffb740 : 0xffffff80127aef97
0xffffff82f5ffb860 : 0xffffff80127aede3
0xffffff82f5ffb8d0 : 0xffffff8012a06ee6
0xffffff82f5ffbb10 : 0xffffff8012a08733
0xffffff82f5ffbf00 : 0xffffff8012a08276
0xffffff82f5ffbf40 : 0xffffff8012db9bfd
0xffffff82f5ffbfa0 : 0xffffff801275d196
It only seems to do it with one disc, the rest are fine so I am assuming it isn't a general problem with the program.
mrdrummond
Did you ever figure it out ? my mac does it to.
Is MakeMKV crashing on a specific disc? Perhaps your Mac is having a kernel panic and restarting?
mrdrummond
i suspect the external ssd and the external rip drive are pulling too much current from the usb bus.
