How can I downgrade for WH16NS40 1.04?
Edward062
Post by Edward062 » Thu Dec 05, 2019 10:08 am
I purchased the UHD drive WH16NS40 last week, but the fw is 1.04. how can I downgrade for it? Thanks
Not found the MK or DE firmware for it. please... Or I need to re-order another one?
Edward
st4evr
Re: How can I downgrade for WH16NS40 1.04?
Post by st4evr » Thu Dec 05, 2019 6:50 pm
Forum search function works. Learn to use it. It may save you frustrations and headaches as it will provide answers to common questions. There are plenty of discussions on these options already.
Examples:
https://www.makemkv.com/forum/viewtopic ... .04#p80394
https://www.makemkv.com/forum/viewtopic ... 16&t=21015
In short, you’ll have to cross flash it to a compatible “sister” firmware, then flash whatever else you’d like to use from then on.
