Key
charlie62
Key
#1 Post by charlie62 » Thu Dec 05, 2019 12:26 am
Hi there I had a major screw up with my pc which was running windows 7 but rather than put that back on I changed over to windows 10. My problem is not that it doesn't work,no my problem is I was using the registered version and now I'm on the trail version.
And as my pc went kaput I have no way of knowing what the key was or how to ask for another can anyone help me out on how I re-register thanks
Re: Key
#2 Post by d00zah » Thu Dec 05, 2019 12:44 am
Re: Key
#3 Post by Billycar11 » Thu Dec 05, 2019 2:04 am
also you can check your email search for this it is where one of my keys came from
2Checkout / GuinpinSoft inc <no-reply@2checkout.com>
charlie62
Re: Key
#4 Post by charlie62 » Thu Dec 05, 2019 2:12 am
Done that a few hours back,now just waiting on reply
