Key
charlie62
Key
Post by charlie62 »
Hi there I had a major screw up with my pc which was running windows 7 but rather than put that back on I changed over to windows 10. My problem is not that it doesn't work,no my problem is I was using the registered version and now I'm on the trail version.
And as my pc went kaput I have no way of knowing what the key was or how to ask for another can anyone help me out on how I re-register thanks
Re: Key
Post by d00zah »
Re: Key
also you can check your email search for this it is where one of my keys came from
2Checkout / GuinpinSoft inc <no-reply@2checkout.com>
charlie62
Re: Key
Post by charlie62 »
Done that a few hours back,now just waiting on reply
